Question about Watches
How to open a m.z berger aw222 watch to change battery
Posted by troy denniston on
Marvin
    Top Expert:
  • Watches Master
  • 85,239 Answers
Take it to a local jeweler and they have a special tool.
Posted on Sep 01, 2017
How to set time on m.z. berger wrist watch
Hi Hollywoo,
As far as I can see Berger watches all have what I would call a winder knob. You normally pull this out gently and then turn it to move the hands of the watch - ie: to set the time. When finished just push it back in.
Aug 08, 2015 | Watches
How do I change batteries on a M.Z. Berger AW 213 watch
I know it's been a while since you posted this question, but I just had to do this with mine after it was lost in a drawer for a few years, and I had no luck googling so I had to figure it out for myself.
First, you have to remove the band, but you only need to do this on one end, not both. I did this by twisting the watch body around while holding the cloth/leather portion of the band still, letting the elastic part twist around with the watch body. Then, just use a fingernail to pull on the ridges on one end of one of the pins that are holding the band on; both ends are spring-loaded, so it doesn't matter which. Twist the watch body back around, and you'll now be able to flip it over to expose the back.
Now, take a thin, strong blade (I used a butterknife) and pry off the back plate. There's a tab on the upper right edge of the back plate to make this much easier. Since it probably came off in the process, place the rubber sealant ring back around the edge of the backplate.
Once you have the back plate off, there's a thin metal piece covering the battery that's held on with one screw. Remove that with an eyeglass screwdriver or any other similarly-sized Phillips-head screwdriver. There's just a small tab holding the metal piece in place on the other side, so just flip the metal piece up a bit and pull it out. You can now take the battery (a CR2016 3-volt watch battery) right out.
But wait, what's this? Beneath that battery, separated by a small plastic insert, is another, smaller one, a 377/376 1.55-volt watch battery. The 377/376 powers the analog movement, while the CR2016 powers all the digital stuff and the backlight.
Replace both batteries, making sure to place the plastic insert back on top of the 377/376 before putting the CR2016 back in, and follow the steps in reverse to put the watch back together. You may have some difficulty getting the back plate back on, but I just pressed one side in and held it while I tapped the other side down with my fist.
Apr 28, 2014 | Bulova Watch
Where can i find a user manual for berger pressure cooker bg-1692
I think you meant Berghoff?!?
http://www.hippressurecooking.com/berghoff-pressure-cooker-instruction-manual/
Apr 28, 2014 | Watches
How to set the time on a digital watch
Hi, you need to find the little black "set" button which is located on the right side of the watch between the two functioning buttons. its very little. Press it once with like a needle or a pen tip (because you cant reach it with your fingers). You can then set the time.
Jan 12, 2014 | Watches
Need to add links to a new Elgin watch band. The number on back of watch is SR626sw
That's the battery number for the watch also known as the #377. It's the most common watch battery in the world. Your model number is located at the bottom of the dial (face) below the six-o'clock position. You will need a 10 power jeweler's loupe or magnifying glass to see it and read it. Jot down the number and contact Elgin directly (MZ Berger Co,) for the extra links.
MZ Berger.
Jun 20, 2011 | Watches
My watch didn"t come w/
Hi
This might help you having a manual.
There are two options to get a manual:
1. thru mail, you need to provide the style number found in the back or beneath the number 6 on the watch.
2,. Thru phone, you need to provide the style number then the warranty and instruction will be mailed to you.  Also can give to you over the phone.
Customer care number:  718 472 7500
Customer care Fax Number: 718 472 7661
Address:
MZ Berger and Company
Attn:  Service Department
29 - 76 Northern Boulevard
Long Island City, NY 11101-2214
Also for more information you can click this link.
I hope this will help you.
Thank you for choosing Fixya.
Mar 09, 2011 | Watches
M.z berger prt 138. How do I set it?
Contact manufacturer. Might have the information
Contact Us Berger Co
May 07, 2010 | Watches
Watches Logo
492 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
