Watches Logo
Padam Bhusal Posted on Sep 01, 2017
Pls assist me setting fossil 5210 chronograph watch with 3 dials
6helpful
The dials on the watch mean what? Do I have to
Go to Fossil.com, choose your area and then go to the bottom of the page.
There you will see "customer care", click on this and on the next page you will see a menu on the left.
Choose instructions and you will then see a list of sketches with watch types (generic)
It may take some searching but you should find what you need here!
1helpful
How do i use and set my fossil ch2589
You can get instructions for your watch from the Fossil web site.
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Click on this and a list of diagrams and watch descriptions will appear,Download the file that is suitable for your watch.
2helpful
HOW TO WORK THE SUB DIALS
This is an Architect Chronograph. To start the chronograph press the top start button. To stop it press it again. To reset it press the reset or bottom button. The sub dials are minutes, hours, and seconds.
I can't set the date on my Boyfriend 3-chronograph MOP black dial watch. Are there any instructions?No manual in box, only registration form. Thanks.
The Fossil web site has all of the instructions: https://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
The glass front came out of my Chronograph Black Dial fossil watc
Go to a watchmaker/technician. They will have a press that they can use to apply even pressure putting the crystal back in place. Be careful that you do not lose the teflon seal sitting where the crystal goes and do not let any dirt or contaminants get to the face of the watch. Be sure you ask them to pressure test it to be sure it is water resistant.
3helpful
Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
20helpful
2answers
Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
Oct 01, 2008 • Watches
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
