Vacuums Logo
Question about Bissell Vacuums
Can you help me with my Bissell Power fresh steam mop?
When my steam mop was not making steam, I took the head apart.
5 Related Answers
Anonymous
SOURCE: My steam mop does not make steam.
how do you get a shark steam cleaner unclogged?
Posted on Jul 14, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Shark Steam Mop: Won't steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Posted on Mar 05, 2011
Anonymous
SOURCE: Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Posted on Mar 26, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I loved my Shark Steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on May 19, 2011
Anonymous
  • 3 Answers
SOURCE: For some reason, our shark steam mop stop working. Usually after I plug the steam mop, the power light would light up then you would hear & see steam coming out of the mop's head but all of
HEATING ELEMENTS BURNT OUT. WILL COST OVER $100. TOFIX. SHARK NOW HAS A NEW MODEL "SHARK 3" MUCH BETTER
Posted on Jun 19, 2012
How do i unclog my bissell power fresh steam mop?
Soak the reservoir with half vinegar and half water over night. This will clean up calcium and lime deposits. Also, straighten a paper clip and insert in the holes where the steam comes out. For future advances, aleays pour the wster out and let air dry. I keep my lid off of mine when not in use. I just put it in a ziploc bag and attach it to my steam mop.
Need a diagram of the water reservoir for the shark s3202
Shark steam mop not sending steam to attachment
It sounds like the head could be clogged up. Try running water in the head and see if that works
Will not make steam. It was working fine & then just stopped making steam.Can I take it apart?
heatman101
3helpful
2answers
The water tank is getting really hot,steams come out the sides of it but no steam is coming out the bottom.
I was having the same problem. No steam out the bottom. I took the whole thing apart and cleaned it...inside and the mop heads. I now get water to the heads but steam is still coming out the sides of the unit and leaking. I took it apart again and this time had my husband look at it. He found a tube with a spring in it...the spring had punctured the side of the tube and was leaking inside the machine! I am really upset by this as the machine never really worked right from the beginning but I really did not know it was not supposed to work this way. Now the machine is over a year old. I will be calling tomorrow and complaining but am not very optimistic that they will do anything and from what I have been reading will NEVER buy another one!
15helpful
2answers
In the middle of mopping, unit light went off - no steam either. My husband took it apart and saw a burnt area on one of the connections. He tried to remedy, still no power
They are not built well...
heatman101
Long spring
The spring goes on the hose to give the plastic tubing some support...
heatman101
4helpful
Took apart the s3101 and there is a long spring inside..where's it go. It's not obvious
The long spring goes over the plastic tube that goes to the head to support the tubing...
heatman101
Shark steam mop
The spring slides over the hose to support the hose...
Hereis a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not begetting steam to the head...
heatman101
Top Bissell Vacuums Experts
Marvin
Marvin
David Shaub
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
