Question about Schlage Locks & Locksmithing
Have a Schlage 595 keypad lock. The programming code does not work. What can I do to add more 4 digit codes
Posted by Joyce Larsen on
5 Related Answers
Anonymous
SOURCE: how to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Posted on Sep 30, 2008
Anonymous
SOURCE: Schlage electronic keypad lock doesn't work
I have the same/similar problem. I called the company 888 number. The customer rep promised to send me a new one. good luck
Posted on Jun 09, 2009
Anonymous
  • 59 Answers
SOURCE: I have the same kind of problem
Restore the lock first
1.disconnect battery
2.press and release the SCHLAGE button
3.reconnect the bat and wait until SCHLAGE is no longer lit.
4. within 10 sec,press and hold SCHLAGE until SCHLAGE lights green and the lock beeps.
The lock is back to factory now.
Now add your user code.
Adding a new user code
DPC is-digit programming code
DUC is digit user code
Yellow sticker has factory 6 digit programming and 4 digit user code on it.
1. 6DPC push SCHLAGE, push 1, enter 4DUC twice.
this lock will only take 2 user codes.
Hope this helps. Leave feedback for others if it helps
Posted on Aug 30, 2009
Testimonial: "Yes this did the trick. I changed the programming code so long ago I could not remember it. "
Anonymous
SOURCE: Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
Coaltowner
  • 963 Answers
SOURCE: I can't find the code
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Posted on Mar 05, 2011
Programming code will not work
I work for factorylocks.com. We get programing questions all the time for Schlage FE575/595. The factory default programming code and PIN codes are on a sticker stuck to the inside of the front housing of the lock. You will need to take the lock off of the door to see this sticker. Once you have done so, reset the lock back to the factory defaults and reprogram the locks to your settings using the programming instructions you can find here http://www.youtube.com/watch?v=z8BgHP712eg
Feb 03, 2013 | Schlage FE595 Plymouth Electronic Keypad...
I have spent over an hour looking for information on how to set a code for my Schlage BE365 CAM 619 keyless access deadbolt. I want a very SIMPLE explanation. Don't tell me to go to the Schlage web...
First make sure you have a fresh new battery installed
Next if you feel you have fiddled with it so much you can reset the lock to the factory default settings, to do this
1.Disconnect the Battery
2. Press and hold the Schlage Button while reconnecting the battery
However proceed before resulting to a reset and see if you are sucessful.
There are preprogrammed user codes already programmed into the unit
These two USER CODES (UC) are on the Yellow Sticker and on the Installation documents that came with the lock. Also the 6 Digit PROGRAMMING CODE (PC) is listed in the same location.
Assuming the lock was installed correctly and tested for correct operation.. proceed...
First.. I agree with you about the instructions.. many places they use the word "press" when they should have used the word "enter".. or phrase.. "enter the user code by pressing the corrosponding numbers".. however..
With the door open test the lock function
Press the Schlage button.. this should extend the bolt
Next Enter one of the two supplied preprogrammed user code (a) or (b) and rotate the thumbturn away from the door edge (generally to your left or counter clockwise) This should retract the bolt.
To Enter a New USER CODE (UC)
1.Enter the 6 Digit Programming Code (PC) via the key pad
2.The Schlage button will glow Orange
3.Press and release 1 on the keypad
4.Enter your new/desired 4 Digit USER CODE (UC) via the keypad
5.Enter the new/desired 4 Digit USER CODE (UC) via the keypad again (yes a second time)
The Schlage button should flash green.. signalling the program was sucessful
Repeat the lock function test using the new User Code (UC)
Make sure you write the new UC number down.
This lock will store up to 19 UC codes.
Good Luck!
Mar 11, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
I can't find the code for my schlage keypad lock. Is there any way to reset my passcode without the original code for the lock
Feb 15, 2011 | Schlage Locks & Locksmithing
How do I set the key pad to my on code on my schlage electronic keyless lock
This link will give you instructions for various models of Schlage locks, including the BE 365:
Jan 13, 2011 | Schlage Lock BE365VCAM716 Electronic...
I have a 4 digit schlage keyless lock and want to reprogram it
There's a video for reprogramming it.
Dec 20, 2010 | Schlage Locks & Locksmithing
I would like to program the schlage deadbolt keypad using my personal code.
There is a video on that page.
Dec 18, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Instructions needed for changing the keypad combination of a Schlage Camelot Keypad Lock 26D. I lost the instructions. Please advise. Send information to [email protected]
Dec 17, 2010 | Schlage Locks & Locksmithing
How do I delete/add/change the codes? I lost my instructions.
Nov 27, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
Manual for changeing code
Nov 12, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
I have the same kind of problem. I have the programming code, but when I enter it, after entering the 4 th digit the lock blinks an error thinking I entered an incorrect user code?? So I think I might have...
Aug 30, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
Locks & Locksmithing Logo
1,388 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
