It is a wet/dry 10 gal 3 hp. The cage seat measures 3.75-inches.
SOURCE: jhe4576. I own a Genie SV125Q, 5 gallon wet/dry
Where did you buy this unit from? Go back there and ask if they have filters for yours. Otherwise look in the Yellow Pages for vacume cleaner repair shops. Sometimes they have all kinds of filters for all kinds of vacumes. You can try places like Wal Mart. What you want to look for are filters that will work with your unit. The foam filter you refer to is called a pre-filter. It traps the bigger particles so they won't damage your paper filter or clog it up especially if it's wet stuff you're picking up. You can remove that foam filter and gently wash it out in the sink with a mild dishwashing liquid and warm water. And even sometimes if you have time you can wash a paper filter out by hosing it out from the inside, with just a gently rinsing on the outside. Don't use any solvents on it just soap and water. And don't use high pressure either, as it will destroy the paper. I have cleaned my paper filters several times before I finally had to replace them. You can also look at places like Lowe's. They carry shop vacs and a whole assortment of attachments as well.
SOURCE: Have a Genie 1.25 HP
Used a roll of toilet paper that what I used when I was drag racing. I am sorry that junky, sorry. Contact you local vacuum cleaner repair shop and see if they one on hand. Go to the Internet and for Genie Vacuum Cleaner web side. I'll bet you they will have it, order more than one. GB...stewbison
SOURCE: I have a 10 Gal
Here are links where the hose can be purchased.
The parts for this Model seems to have been discontinued, but there are some that still sell the part, check the link provided to get more details of the part needed, thanks.
Link1
Link2
Link3
I hope the link help, I saw the hope on Link3 and Link2, on Link1 is where the original part can be bought but has been discontinued in the market, I put the link just for details on what the original part would look like to be able to buy one that the same from the other 2 links.
Have a nice day.
