It says '1H' and then you can press start/stop button to 2,3,4,5H and etc.
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
SOURCE: settings for a new watch
http://www.adidas.com/campaigns/watches_fw07/content/index.asp?strCountry_adidascom=us&strBrand_adidascom=performance
check it here.. you will surely be able to solve it as i have just done...
press top left and it will say HOLD for setting.. so hold it... then choose one step after the other with the left bottom.. and increase with right top and decrease with right bottom.. rest you can find in the manual at the website... good luck...
SOURCE: i cant set the correct time on my candy watch pleaase help????
You can get instructions from their web site (www.adidas.com/campaigns/watches_fw07/content/index.asp?)
Click on "instruction manuals" in the menu on the left, choose your country.
You will be presented with a series of generic instructions from which you should choose the ones that suit your watch.
SOURCE: cant set digital time and date on my adidas 10-0140 watch
click this link for instructions
http://www.adidas.com/campaigns/watches_fw07/content/performance/pdf/performance_en.pdf
Have you been able to find out how to by pass the "offset" option when trying to set the time. I am now experiencing this problem with my Adidas watch. Please help
