Question about Golf
Does solenoid still click? If it does then I would check the motor wires to see if they are still connected. If ok then I would check the forward/reverse switch assuming you have a Lever type mounted on the body of the cart.
Posted on Sep 19, 2017
SOURCE: I ned a service manual for a 1995 ezgo dcs golf
Our EZ GO golf cart will start and run except you have to hold the choke about half way out for
it to continue to run. What is wrong?
Posted on Apr 20, 2009
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
Posted on Apr 21, 2010
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Posted on Apr 22, 2010
Aug 02, 2017 | Golf
May 23, 2017 | Golf
Oct 20, 2016 | Golf
Jan 02, 2016 | EZGO 1995-99 DCX600 Controller 600 Amp...
Sep 09, 2015 | Golf
Aug 31, 2014 | Golf
Aug 06, 2014 | Performance Plus Carts EZGO Golf Cart 36...
Jul 18, 2014 | Dual Pro 36V 25Ah Golf Cart Battery...
Mar 25, 2010 | 1995 Volkswagen Golf
Jan 19, 2020 | Golf
Oct 16, 2019 | Golf
1,002 people viewed this question
