SOURCE: hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
SOURCE: Servicing Hobart A-200
the bondo is on the top cover, most likely covering the screw holes up. I've scrapped the paint off and see bondo on it, I know it also has been repainted a few times as well. It just strikes me odd to find this. thanks.
SOURCE: Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant. I think the difference is mostly in terms of the no volt interlock switch. This means the KA style N50 bowl won't work with the CE models - too low.
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
SOURCE: reccomendations on how to move a Hobart H600 Mixer
I would use the 4 wheel platform dollies and ratcheting tie-down straps to secure it to the dollies.
I have used these to move pianos and other larger objects, but make sure that you secure the object to the dolly and get the best one with the biggest wheels that you can find. The bigger the wheel the easier the roll. Not sure how big your doorways are, but if you can use 2 or 3 dollies, that’s what I would recommend. Just make sure that you secure the load with ratcheting straps not just rope.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” (Two Thumbs Up) rating then please comment to this post and I will try to help you further.
I try to provide the best FixYa experience.
