SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
SOURCE: green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
SOURCE: Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: ceiling mounted PJ551 - lamp light red, power light blinks red
I have PJ 550 exact SAME PROBLEM replaced bulb NOTHING
