SOURCE: Sharp Electronic Organizer ZQ-6000
I couldn't find any support for this on Sharps USA website. You should contact them directly at:
1-800-BE-SHARP
SOURCE: Missing Control Panel+Run Command+Active Desktop
Does your computer have a systems restore option . If so try to set it to a date before these problems occured and it should fix itself....Click on start, then accessories, then system tools, then system restore. Pick a date before the problems started an restore to that point. Should do the trick.....
SOURCE: deleted yahoo mail folder, sent items, & drafts
one of the important yahoo folder that i have was deleted, my draft folders went empty, my sent items,,, some of important sent items that i have are all gone,,,, how can this be possible???
SOURCE: Retrieve Password without losing data with Sharp Organizer
According to the YO-370 Operation Manual:
What To Do If You Forgot The Password -
When you have forgotten the passord for the SECRET function, you have to delete the password along with all secret data by selecting "DATA DELETION" from the Function menu. Once the password is deleted, a new password can be entered. Follow the procedure below to delete the password (and the secret data along with it).
1. Recall the Function menu (2nd, FUNCTION)
2. Select "3 DATA DELETION", and press v (3, v)
3. Select "3 SECRET DATA". (3)
The delete prompt "DELETE ? Y/N" appears
4. Press Y (To retain the data, press N)
When Y is pressed, both the password and the secret data are deleted, and the initial display for the previous mode in use will reappear on the display.
Camp cupboard will allow you to keep items safe and well organized, what should make the searching process very short. Camp cupboards are advised to be used only for trip with a car or a RV.
