Question about Stihl Saws
The saw won't cut like it should it pulls away from the wood.the dampers are broke.
SOURCE: Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Posted on Nov 19, 2008
SOURCE: Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Posted on Jan 03, 2009
SOURCE: mccullough chain saw pm610 chain slips -- maybe clutch issue
I just had this problem. It is possible that your chain drive teeth have jumped off the drive sprocket. There is a guide for the chain to follow and is decievingly difficult to verify that the teeth are in the drive sprocket. Turn the saw upside down, and look at the clutch. Check the chain to see if the chain is actually on the sprocket and not beside it. It looks right, but it's not.
Posted on Jan 12, 2009
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Posted on Feb 14, 2009
SOURCE: how do i replace the pull cord on my stihl cut off saw
it is gonna take some time,take all screws off housing,pull casing off,be careful with the rewind spring and be sure you have spring wound-up for re-install.
Posted on Apr 24, 2009
Mar 14, 2017 | Stihl Garden
Oct 29, 2015 | Stihl MS171 12" Chainsaw
Oct 07, 2010 | Husqvarna Chain Saw 20" Bar
Jul 21, 2010 | Stihl 18" Chain Saw Bar 3005 008 4717
Oct 06, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Sep 21, 2009 | Garden
May 08, 2018 | Stihl Saws
183 people viewed this question
