Question about Kenmore Kitchen Ranges
I have a Kenmore gas range model # 665.75029 and today I found it in LOC with burner emblem mode. I tried to reset holding Cancel and a EO & FO code appeared with burner emblem. Is there a way I can reset the stove so I can use it. The igniter still works just no gas to burners. Thank You
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
If you hear clicking or sparking, go to Step 2.
If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
Check to see if the burner works, If not, then go to Step 3.
Check to see if the burner works, If not, then go to Step 4.
Posted on Sep 01, 2008
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
Oct 19, 2015 | Kenmore Kitchen Ranges
Nov 12, 2013 | Kenmore Kitchen Ranges
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Mar 12, 2009 | Kenmore Kitchen Ranges
Oct 19, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Apr 21, 2008 | Kitchen Ranges
106 people viewed this question
