I called Bonaire support they said they dont know because usually this error is caused by faulty circuit and faulty ignitor. the model is MB4 30E Anyone can help please im freezing !!!!!
SOURCE: Dayton Infrared natural gas heater ignition/flame sensor
Yes, the flame sensor is part of the intermittent pilot assembly. Check the following: make sure all grounding wires are secure and no corrosion is built up on them. Clean or replace the pilot assembly, also clean out the orifice with a very small drill. Make sure the sensor is in the flame and make sure the pilot tube is not leaking gas reducing the gas pressure at the pilot.
If it continues, you will have to replace the ignition control.
SOURCE: Carrier Furnace 58gs075-1 Circuit board issues...
I cant see your wire diagram but trace the circut your talking about. I believe it usually goes through a series of safety switches. Put your VOM across each individual switch. If you get 24 out from the board the first 1 you check and get 24v is open and not feeding back to the board is out. FIND out why. the switch could be bad but it may be indicating a more involved problem, just look aroeund for chared wires or tell tell signes of flame roll out or if its an open (fuse link) suspect what can cause an over heat condition anythign from a bad board or too long an off cycle before the indoor fan comes on ect. PONIT IS Once you come across the cause may not be the reason.
Please grade me accordingly and if you need more I need more info from you.
SOURCE: Mine has 7 red blinks and wont come on. i pulled
No, your done. Now replace the Y-Main, that's the large one you found the fuse blown on and replace the two buffer boards that the Y plugs into. Those are the two at the far left. The part numbers are on the boards. So that's 3 boards you will need. sometimes they sell the buffers together as a pair which is cheaper. DO NOT buy from second hand resellers. Always buy new when it comes to plasma sets.
SOURCE: Jaguar 2002 X- Type Code P0057
Here are the locations of the fuses and relays. F-31 through f-42 probably are the one you want to look at. These are probably all tied together from looking at your codes. Your mass air flow sensor is also giving you an alarm. If your not finding any blown fuses or bad relays it might very well be the PCM (Power train control module) itself that is going bad. A dealer will have to check that out for you.
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger
