SOURCE: have a norcent mdl315 dvd
there are many sound output jack from the back of a dvd players .If you are going to connect it to a TV you can use the rca output jack labelled audio out front L front R or main L and main .This sound out put requires an audio amplifier to process the signal output into a sound signal..Do not connect it directly into a speaker for there will be no sound you can hear.good luck and let me hear if you have if you need further assistance.
Sounds like you have a faulty Drive/ Eject door motor, Snapped drive belt if a noice can be heard or the Motor driver chip has malfunctioned.
When you press eject listen for a noise like a small humming from the dvd drve part, if there is a hum then more than likely your belt has broken which is inexpensive but if nothing can be heard then its likely the motor or Driver Chip. The motor can be easily replaced if found on an auction site.
Jon
