Question about Stanley Vehicle Parts & Accessories
Stanley Fatmax 450 Amp (Model J45TK)compressor starts and then stops right away. The charge is full showing the green LED light on.
Posted by ram Takka on
coatings35
    New Friend:
    Problem Solver:
  • 11 Answers
You will likely have to open up the case to look inside.
The main components will be a circuit board, a 12v power supply, a 12v air pump and a 12v rechargeable battery. It sounds like a loose connection on the air compressor pump. When you turn it on it normally vibrates and is loud. This may be enough to shake loose a wire connection. If so it should be an easy fix to crimp or solder.
Posted on Sep 14, 2017
5 Related Answers
mpservices
  • 191 Answers
SOURCE: How to basically operate my
Press the red button - (distance) you will see a red dot on the wall you are measuring - then you will hear a beep - release the button and read the display - the measurement should be displayed and accurate within a quarter inch.
Posted on Nov 23, 2008
Anonymous
SOURCE: Lost manual, how do I read LED indicating lights
Manual can be found at
http://www.thorsentoolco.com/Links/PDFs/11-414.pdf
Posted on Apr 10, 2009
K W
  • 509 Answers
SOURCE: I cannot open the Stanley FatMax Retractable
Try this website and scroll down to product description...
http://www.amazon.com/Stanley-10-777-Locking-Retractable-Utility/dp/B00009OYFP
Posted on Feb 01, 2010
Anonymous
SOURCE: i have the endurance 450 amp jump start and no
charger reqwerment
Posted on Oct 03, 2010
puertobori
  • 7733 Answers
SOURCE: Just purchased a Stanley fatMax
Some models has 2 screws on the knife case.unscrew them and you can access to the blade.
Posted on Nov 08, 2010
How can I tell when my stanley 450 amp instant starting power station is fully charged?
I would suspect that the internal battery has reached the end of its life. Surely there is a green light to indicate when it is charged?
Jan 06, 2015 | 450 Amp Battery Jump-Starter
Stanley fatmax 450
Open up the case and look inside. A wire may have come off.
i had a brand new compressor that wouldn't power on. A wire was not connected. After reconnecting and a positive testing I put it back together. It ran for five minutes and stopped. It turns out the wire was too short (factory install) and came disconnected each time the compressor was turned on due to the vibration. I rerouted the wire so it wasn't so tight. Problem solved.
Oct 29, 2013 | Stanley STA-J45C09 450 Watt Jump Starter...
How long do i have to charge the stanley j309 300 amp battery booster
Before the first use, the unit must be charged for 24 hours with a connection to an AC outlet (120V). Make sure that all of the switches are off. After that, stop charging when two red and one green LED Battery Status Indicators light.
If you are recharging the unit from a 12V battery, do not charge for more than 6 hours. (Check for a full charge by disconnecting the DC charging adapter and then press the Battery Power Level button.)
The manual for the Stanley J309 battery jump starter is available on the product page here: http://www.baccusglobal.com/stanley/j309.php . The direct link to the manual is http://www.baccusglobal.com/stanley/manuals/JUMPERS/J309%20MANUAL.pdf .
I hope this helps.
Dec 29, 2011 | Garden
I bought A Stanley 450 jump start & I'm to charge it for 24hr. The 2 red lights are on but the green light is still blinking after 14hr. What does the blinking light mean?
not sure if you found this yet but it is actual made by Baccus Global under the stanley name.
http://www.baccusglobal.com/faq.php
Q: How do I know when my Jump Starter is fully charged?
A: All of the Baccus Global jump starters have a battery status indicator, units can have 2 - 4 LED indicators when all of them illuminate and the green one flashes the unit is fully charged.
Dec 05, 2010 | Black & Decker Jump Start System 450 Amp...
Vehicle Parts & Accessories Logo
681 people viewed this question
Top Stanley Vehicle Parts & Accessories Experts
Marvin
Marvin
Lawrence Oravetz
MrFixitSTTL
Are you a Stanley Vehicle Part and Accessory Expert? Answer questions, earn points and help others
