Question about Mercury Boating
Trying too find out the year of a mercury 25 hp outboard serial no OG033662
Posted by Bob Roskey on
Don A
  • Mercury Master
  • 2,688 Answers
5 Related Answers
Anonymous
  • 187 Answers
SOURCE: 1994 40 hp mercury force outboard with no spark
If the fuel was not treated with a fuel stabilizer than you probably have a varnish build up in the carburetor. This varnish will clog fuel needle valves and jets. You need to disassemble the carb to clean the jets and needle valves. Sometimes cleaner is not enough you need to us compressed air to blow out the jets. Good luck.
Posted on May 13, 2009
Anonymous
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at [email protected].
Posted on Jun 16, 2009
John Fourteen Six
  • 2418 Answers
SOURCE: impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Posted on Jul 05, 2009
Mark Chapman
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
Anonymous
SOURCE: 2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
Posted on Jun 29, 2010
Mercury serial # 1B010234 what year is this motor?
Would have been helpful to know the horsepower. But here are charts you may be able to use to figure it out:
http://www.iboats.com/basics/mercury.html
MERCURY OUTBOARD MODEL YEAR GUIDE 15 25 HP Mastertech Marine
Aug 29, 2017 | Mercury Boating
Mariner 8 hp outboard serial number 0G156538 -- what year is this engine?
Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly
Hey Peter, try these guys.
https://www.marineengine.com/
Jul 03, 2017 | HP Boating
Number serial OD160249
http://www.mercurymarine.com/service-and-support/storage-and-maintenance/faqs/outboards/?category=modelyear send them an email. :)
Jan 06, 2014 | Computers & Internet
Need to know year model for mercury 6hp serial 9494287
I was able to find the following information regarding 6 HP manufactured by Mercury. You can find more information on the boating forums.
http://forums.iboats.com/mercury-mariner-outboards-25/
HP
Cyl.
Beginning Serial #
Year
6214086111961621485612196262155144319636216075131964621745521196562195827819666220961711967622284857196862A910596198662B114231198762B233200198862B3855001989
Mar 14, 2013 | Boating
Serial Number 1001499 Model Mark 25 Mercury Outboard what year?
pinched rom another website:
Every Mercury outboard has a serial number label located on the transom bracket area of the engine. The latest serial number labels display a 2-digit number in a box at the lower right portion of the label. These digits coincide with the last two digits of the year in which the outboard was manufactured. For example, if an outboard was manufactured in 2010, the number "10" would appear in the box at the lower right portion of the label.
Jan 06, 2013 | Boating
Boating Logo
70 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
ray gallant
Are you a Mercury Boating Expert? Answer questions, earn points and help others
