Question about Jacuzzi Home
How is the best and faster way to remove the air of inflatable jacuzzi
Posted by Jorge Sotomayor on
How to get the airbag light to go off on a 2007 Chevy van Express
You need to find out what code or codes are stored in the airbag control module > There are a lot of components involved in your airbag system : If you haven't had any training on these systems your best bet is take it to a ASE certified repair shop . People have been killed messing with these systems not knowing what they were doing .
The frontal SIR system consists of the following components:
AIR BAG indicator located on the instrument panel cluster (IPC)
Driver and passenger knee bolsters
Inflatable restraint front end sensor
Inflatable restraint PASSENGER AIR BAG ON/OFF indicator located on the instrument panel
Inflatable restraint Passenger Presence System (PPS)
Inflatable restraint I/P module
Inflatable restraint I/P module disable switch
Inflatable restraint seat position sensors (SPS) (left/right)
Inflatable restraint sensing and diagnostic module (SDM)
Inflatable restraint steering wheel module
Inflatable restraint steering wheel module coil
Inflatable restraint wiring harnesses
Seat belt pretensioners (left/right)
Steering wheel and column
Nov 22, 2015 | Cars & Trucks
My inflatable therapure jacuzzi tub has a leak on a seam. How do I fix it?
Seam leaks are most difficult to fix on amy inflatable product. However, if yo can find an AC man or an AC supply store that will sell to you they have a tape that is foil on one side and a thick gummy material on the other once in place it is impossible to remove. My brother called it "Hard Cast" but it is not, hard cast is a two part process that will not work for you. This tape has a paper that you must peal off before you apply it.
31644dba-35b4-49c2-9610-b86152d92ddc.jpeg Drain the tub, let it dry, no moisture or dirt or soap residue. Let all the air out of the tub. Then apply enough tape to cover the tare by 2" on all sides. Also trip the tape so that there are no sharp edges. This will not only feel more comfortable but make it harder to peal away. Make sure the tape goes on smoothly and with no wrinkles in the vinyl or the tape. You will only get one shot at this.
May 24, 2014 | Therapure Four Person Inflatable Round Hot...
Why other leter n ke board not function
its just dirty contacts if you can open your keyboard, clean contacts with non rubber eraser like the ones used by engineers and draftsmen. also include the rubber contacts under the keys
Jul 25, 2012 | Acer Computers & Internet
What tyre pressure would you recommend for a 140/70/18 rear tyre
it is best to go with the mfsti, the psi listed on the tire itself but there are some things you can do to adjust this. less ait about 5 10 pounds will give you a softer tire and better handleing. the trade off on this will be faster wear of the tire. over inflating it will give much better feul mileage sharper (not better but you will feel the effect of faster handleing going into and coming out of leans.) the trade off is going to be faster tread wear in the center of the tire. you are going to want to make sure the front and back are the same. i did a under inflate in the front and an over inflate on the rear and it gave me the feel that i liked in the bike. play around with it and have fun.
Feb 22, 2010 | 1984 Honda CBX 750 F
I have an Obusforme inflatable travel pillow. The directions say to pinch the base of the valve to open it. I don't see that this helps to blow it up.
If you pinch the base of the valve while you are blowing air in it it will inflate. The valve becomes mis-shapen allowing air to enter the pillow. Likewise when you let go and the valve returns to normal shape the air is not allowed to escape
Apr 23, 2009 | RTO 2 Inflatable travel pillow Neck Rest...
Toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Dec 28, 2008 | Jacuzzi Bath Era BK37 959 White toilet...
Vinyl air
I have a vinyl towable tube inflated with air.....I need to know how the best way is to patch this to hold air under pressure
Dec 01, 2008 | 3M SportsStuff Speedzone 3 Inflatable...
Tire maintenance
Check your tire air pressure at least once a week and before long trips. Be sure to use an accurate pressure gauge. -Check your air pressure when the tires are cold. The tires are cold when your motorcycle has been ridden less than a mile at moderate speed or after being stopped for three or more hours. -If you must add air when your tires are hot, add four pounds per square inch (4 psi)(28 kPa) above the recommended cold inflation pressure. Recheck the inflation pressure when the tire is cold. -Never release air from a hot tire in order to reach the recommended cold tire pressure. -Normal riding causes tires to run hotter and inflation pressure to increase. If you release air when your tires are hot, you may dangerously under inflate your tires. -If your tires lose more than two pounds per square inch (2 psi)(14 kPa) per month, the tire, the valve, or wheel may be damaged. Consult your local dealer for an inspection. -Use valve caps to keep valve cores clean, clear of debris and to help guard against air leakage.
Nov 10, 2008 | 2007 Suzuki GSX 1400
Home Logo
337 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
