Question about Combi Ovens
SOURCE: RATIONAL COMBI OVEN ELEMENT GLOWING RED -IS THIS NORMAL?
your oven is electric yeah? the hot air element shouldnt be glowing like that, it glows with the door open? the oven has a over temp stat so if the oven got too hot then it would trip out, if it does then the solid state relays will have to be changed, but if it carries on as normal then shouldnt worry
Posted on Apr 05, 2010
SOURCE: water is pouring out of the bottom of Rational oven SCC 101 E
theres a chance you have a deffective solenoid staying open causing the water to overfill the boiler tank and passing out the overflow into the quench box and down the drain!
Posted on Dec 21, 2010
SOURCE: rational combi oven service manual
Alarm beeping control board not working
Posted on Feb 18, 2011
SOURCE: can you please advise me
Unfortunately, the manual for Kenwood CJ99SSA is currently unavailable for download.
You can download and refer to the instruction manual for Kenwood CJ99SS model in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Posted on Aug 21, 2011
SOURCE: does a rational combi oven have a cut off switch ?
First check fuses, then check your donut transformer located at bottom of oven behind water line area
Posted on Nov 11, 2015
