Question about Hardware & Accessories
I have a Kingshield timer T102-c that does notseem to set automatically. But I have to switch it on every day manually.
Posted by Stuart Giesenow on
Gene Haynes
  • Hardware & A... Master
  • 5,391 Answers
Kingshield manuals:
http://waterheatertimer.org/Woods-timers-and-manuals-old.html#Kingshield
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 30, 2017
4 Related Answers
Anonymous
SOURCE: how can I set the automatic timer on the Krups FME2 Coffemaker
Problem solved...
Found the manual for my coffemaker online
Posted on Dec 15, 2008
Anonymous
SOURCE: cannot tell model no for
You posted question under Kingshield plug-in programmable timer.
I have extensive files on timers, and don't show that timer.
1) Add a comment with photo of your timer:
And include voltage that you are working with, and type of Load that timer controls
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Add a comment with clear description of timer and timer buttons so I can compare with my files.
And include voltage that you are working with, and type of Load that timer controls.
3) Open following link to identify same-similar timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 22, 2011
Anonymous
SOURCE: i need instructions for a kingshield electronic
Timer is not identified
1) Kingsfield is Greenbrook:
Open following link to possibly identify timer and download manual:
http://www.greenbrook.co.uk/categories.php?cat=4
2) If timer is not shown, then add a comment with in-focus photo of timer posted on Flicker for possible help.
3) You posted next to a photo that looks similar to timers on following link:
There are other models of this timer that I have no manual for, so add a comment with clear description and link to photo.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Posted on Jun 26, 2011
Anonymous
SOURCE: T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray: With my Intermatic T102, the manual on/off switch ...
Open following link for troubleshoot checklist
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Posted on Jun 28, 2011
HOW TO RESET A KINGSHIELD IMMERSION HEATER TIMERundefined
http://waterheatertimer.org/Woods-timers-and-manuals.html#PB
Identify timer among timer modules shown on link above
Gene
Oct 02, 2014 | Hardware & Accessories
Where can I findkingshield timers e-mail address please
Kingshield does not make timers... they repackage other brands
Look up Greenbrook timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
http://waterheatertimer.org/How-to-set-timers.html
gene
Oct 01, 2014 | Hardware & Accessories
Can i change the model T101P3 timer from 110 to 220?
1) Yes. Change clock motor from WG1570 to WG1573
Wiring is same as T102 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T102
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) If new pump motor is 2-speed, then converted T101P3 cannot handle 2-speed pump.
Use T106 timer, or T1906 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html#pool
3) New T106 or T1906 timer mechanism will snap into T103P enclosure without changing boxes.
Any intermatic timer will snap into Intermatic enclosure.
Other brands of timer can adapt to Intermatic enclosure using Tork IAP adapter bracket.
Mar 10, 2013 | Hardware & Accessories
The power is working, but the yellow timer does not move. It's a brand new unit.
Wires from breaker are probably reversed with wires from Load
Call Intermatic.
Or copy following link for wiring:
T172 timer wires identical to T102:
Nov 11, 2012 | Intermatic T172 24 HOURS 40 AMP 208 277...
Cannot tell model no for a kingshield 7 day plug in timer
Mar 18, 2011 | Hardware & Accessories
Hardware & Accessories Logo
252 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
