Question about Hardware & Accessories
I have a Kingshield t192-c 24 hour timer that i cannot set to operate automatically
Posted by Stuart Giesenow on
Gene Haynes
  • Hardware & A... Master
  • 5,391 Answers
Some Kingshield manuals appear following link:
http://waterheatertimer.org/Woods-timers-and-manuals-old.html#Kingshield
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 30, 2017
3 Related Answers
Anonymous
SOURCE: cannot tell model no for
You posted question under Kingshield plug-in programmable timer.
I have extensive files on timers, and don't show that timer.
1) Add a comment with photo of your timer:
And include voltage that you are working with, and type of Load that timer controls
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Add a comment with clear description of timer and timer buttons so I can compare with my files.
And include voltage that you are working with, and type of Load that timer controls.
3) Open following link to identify same-similar timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 22, 2011
Andy Turner
  • 910 Answers
SOURCE: timer switch mode is inoperable.
With the Dehumidifier switch on, pressing the Timer Button should changed between 2hr and 4hr mode.
If this is what you're doing and it isn't lighting the LED nextto the 2hr and 4hr can you confirm what setting you have for the humidity?
Posted on Jun 25, 2011
Anonymous
SOURCE: i need instructions for a kingshield electronic
Timer is not identified
1) Kingsfield is Greenbrook:
Open following link to possibly identify timer and download manual:
http://www.greenbrook.co.uk/categories.php?cat=4
2) If timer is not shown, then add a comment with in-focus photo of timer posted on Flicker for possible help.
3) You posted next to a photo that looks similar to timers on following link:
There are other models of this timer that I have no manual for, so add a comment with clear description and link to photo.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Posted on Jun 26, 2011
HOW TO RESET A KINGSHIELD IMMERSION HEATER TIMERundefined
http://waterheatertimer.org/Woods-timers-and-manuals.html#PB
Identify timer among timer modules shown on link above
Gene
Oct 02, 2014 | Hardware & Accessories
Where can I findkingshield timers e-mail address please
Kingshield does not make timers... they repackage other brands
Look up Greenbrook timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
http://waterheatertimer.org/How-to-set-timers.html
gene
Oct 01, 2014 | Hardware & Accessories
I lost instructions for setting Woods Outdoor 24-Hour Mechanical Timer. I set time of day and pressed down tabs for on and off time, but nothing happened. What more do I need to do?.
1) Copy following link for how to set analog timer by experimenting with features.
2) Usually you move slide switch to timer, and make sure load is ON and operable before plugging into timer.
Dec 10, 2012 | Woods Outdoor 24 Hour Mechanical Heavy...
Cannot tell model no for a kingshield 7 day plug in timer
Mar 18, 2011 | Hardware & Accessories
On Intermatic HB65R Timer, how do I set AM/PM or 24 Hour cycle ?
HB65 manual is not available.
Intermatic has pared-down it's timer line recently.
Some old manuals still show, but those are disappearing because timers don't last forever.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
HB61 manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
HB61 timer has a photo-cell switch and automatically turns ON at dusk, and then you set timer for how many hours it will operate before turning off.
Nov 23, 2010 | Hardware & Accessories
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk unless you set override feature shown below
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Hardware & Accessories Logo
128 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
