SOURCE: problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
SOURCE: The PC on which I had itunes that synced with my
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
SOURCE: What is the specifications of the new iPad HD?
Hi Steven,
You can access the new iPad's specifications on the official Apple website. The specs on the new iPad (or iPad HD) can be found by clicking here.
In terms of weight, you are correct-- the new iPad is just over 1/10th of a pound heavier than the iPad 2. Usually devices get lighter as they get deeper into the development cycle, but this was a decision Apple probably made in order to fit their bigger battery into the device (which was needed because of the new Retina Display-- a beauty, but a battery hog).
How you felt the 1/10th of a pound difference I don't think I'll ever know. Either way, good call!
