Question about MTX Car Audio & Video
My mtx amp 3 lights are out but the bass still works why
Posted by Roy c nelson on
5 Related Answers
SOURCE: My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
Posted on Oct 03, 2007
mjap
Mark Payas
  • 107 Answers
SOURCE: Need info
how much power "wattage" does your speakers have and mtx is too powerful right? so need a good quality speakers. reply me with the wattage of the amp and the speakers.
Posted on Jan 18, 2008
Robert marquette
  • 102 Answers
SOURCE: i have a mtx x1000d and i cant get the remote bass to work
These units usually are "smart", as when you are all the way down the received input is too low to activate the control and when you are all the way up it is protecting the amp and your ears.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Posted on Mar 11, 2009
kcarmax
Kevin Simoneau
  • 30 Answers
SOURCE: i have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Posted on Mar 01, 2010
Anonymous
  • 5 Answers
SOURCE: mtx 801d amp turns on but no bass just high pitch
if theres a switch on ur amp that says LPF Full or HPF put it on LPF for low pass frequencies
Posted on Mar 19, 2010
Mtx tna251 amp has bass remote that has a light glowing but turn knob up and down and no difference like simply not working no difference in bass? Posible causes,
It is actually in the controller, if you turn the remote all the way down and press on the controller until the bass goes off, you will be able to turn the bass up and down with the remote, mine worked but stopped after a month, I tried adjusting the amp but then I noticed that if I wiggled the knob on the remote that it would work, I mashed mine until it worked again and velcroed it to my console sonibcan get it on and off easily.
Mar 03, 2015 | MTX Car Audio & Video
I recently purchased the mtx terminator amplified bass system and wired everything in, but the amp seems to not be working, i checked the power and the wires going in are a good circut but none of the...
If none of the lights are coming on for the amp then the amp is not getting power and/or ground. Check the connections. Check the fuses. Or the amp is no good.
May 05, 2011 | MTX Car Audio & Video
When i plug the phonejack style bass controller in all the bass quits and as soon as i unplug it the bass come back instantly. also, next to the spot where you plug the bass controller to the amp there is...
I am guessing the bass control is just a potentiometer that you plug in. It could be open and that is why the bass dies. As far as the switch goes, I am not familiar with the amp but it sounds like a crossover between low frequency and subsonic frequency.
Dec 16, 2009 | MTX Thunder 801D Car Audio Amplifier
I have a mtx x1000d and i cant get the remote bass to work
Mar 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
Mtx
Well it could be that your ears just got used to the bass. It happend to me after about a week of haveing my subs. And make sure that your power wire hasnt got melted somewhere. also that you have good ground.
Apr 13, 2008 | MTX 3002 Car Audio Amplifier
Need info
Jan 15, 2008 | MTX 3002 Car Audio Amplifier
Subs will go off the wall with bass, but not in tune with music.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
Nov 23, 2006 | MTX Thunder 8302 Car Audio Amplifier
Car Audio & Video Logo
56 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Steve F
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
