The glass covering the door to my Bosch HCS445UC/01 just fell on my feet when I opened the oven door. I found one screw in the warming drawer at the bottom and looks like there should be three. At the top a piece of one quarter inch high, inch long of green plaid foam tape unpeeled. SERIOUSLY! I will assume I need to get two more screws to secure the bottom but have no diagram for attaching the top. I have my owners manual . . .
First of all, oven doors are not designed to be disassembled for cleaning of the sealed glass panel. That being said, you may be able to use a coat hanger to pry the hinges open against heavy spring pressure to allow reassembly.
if the grill section is behind the oven door then the door should be open
if there is a door for the grill section then the oven door can stay closed
to get a user manual ,go google and type in-- user manual for bosch oven model ( type in what you have) --( or leave it out if it doesn't recognize the model)
If a page is available with a pdf version you can down load it
contact the service agent for that make and model of the oven
if individual parts are available then they will have them
other than that find an appliance repair shop as they may have a spare door off a machine that cannot be repaired
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
There is probably a retaining bracket behind cooker front panel you will probably have to remove a side panel to access the retaining bracket.
Please rate my solution.
Thanks.
yes you need to go online to bosch website and look for quickfinder this is the tool used to locate spares, the site is for bosch neff seimens as they are all one company put in your enr number or model number and you will get an exploded diagram of your oven you can then find part number.
I looked and it appears to be 297595 in brown or 297601 in white retails at £61.03 ex vat
