Question about iLO 3200 32 in. LCD Television
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
I can't get the TV to respond to anything other than on/off. I have tried from the side buttons and from the remote. I can turn it on and off but no menu, +/-volumn,+/- channels, entering channels by numbers....none of the buttons on the remote do anything except the Power button. It comes on and reads ANALOG TV as usual then identifies the Channel A 47 with the word Mono underneath.... It plays the channel just fine but that's it..... just that one channel.... Then last thing I recall having done was gone into the TV Menu and set the channels... Could I have screwed something up there? Is there a way to reset the thing back to factory defualts? I have the exact same problem the on and off features are the only thing that works on the tv and remote.
Posted by versa07 on
Anonymous
  • 203 Answers
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Posted on Nov 22, 2007
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
Nothing works but the power . it has a great picture but you cannot control the volumn or change channels. what can be done to fix it.
nothing works but the power . it has a great picture but you cannot control the volumn or change channels. what can be done to fix it. ...
Sep 15, 2010 | iLO 3200 32 in. LCD Television
I have an ilo 26HD TV and the remote will not change volumn or channel. The buttons on the side of the TV are not functional either.
Try leaving your TV off for a while at the switch and then try again
if nothing call to where you got it from make sure that everything is plugged in too good luck!
Sep 30, 2009 | iLO 3200 32 in. LCD Television
Ilo 32HD NO Channels! buzzing noise
the input setting may need changed on your tv
Dec 09, 2008 | iLO 3200 32 in. LCD Television
This particular model of tv has a problem with the control board. This is a common problem with this unit. You can find control boards on EBay, or through a local technician. Please refer to our online technician list for a professional near you.
Good luck :)
Jun 10, 2008 | iLO 3200 32 in. LCD Television
Ilo remote RC-370c
the remote do not respond it just turn the tv on and off but thats it
Apr 19, 2008 | iLO 3200 32 in. LCD Television
Tv does not respond to channel changes
The simpliest solution is always the best - I called the cable service provider; they reported an outage and quickly remedied the situation - but also tried to sell me their digital TV package. Thanks for your response.
Feb 16, 2008 | iLO 3200 32 in. LCD Television
Add me to the list also, this was the worst electronic purchase I've ever made. The 26' HTDV worked for 1-year.
Will not resond to change channel, volume, menu access.... neither from TV or remote. Just turns on and off. The channel it is set on work fine just can't adjust.
Aug 09, 2006 | iLO 3200 32 in. LCD Television
I recently bought an ILO 32 HDTV with the same problem. I searched every site I could find for a solution. I finally found someone that gave me the direction to replace the Main Board for the TV. This is the board that you can plug your exteranl devices into, computer, dvd, HDMI etc.
The phone # to Digital Age is 909-974-2859. These are the people who can send you the part you need. Also the remote that I have is RC-500, which is the newest remote control for the new Main Board. I would suggest getting this remote.
The price of the board was $123.89 with $10.00 shipping. It only took 4 days to get the board from Ontario California, and yes they do speak english.
I removed the backpanel myself and then removed the metal cover over the Main Board. Remember to mark all of your wires and screws so you can put them back in the same location. The connections are all quick disconnects and the board is one piece. I had the board replaced and the back panel back on within an hour. All buttons working on the TV and the remote control, and the TV is working great with sound.
But I do not have the Manual......does anyone have the manual? I am willing to help anyone with a fix for their TV for a copy of the TV Manual.
I hope the information I have given helps in anyway possible,
Johnny
Aug 08, 2006 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
260 people viewed this question
Top iLO Televison & Video Experts
Ekse
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
