Question about Mercury Boating
How do you set the timimg on a 1977 85 HP mercury outboard
4 Related Answers
Anonymous
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at [email protected].
Posted on Jun 16, 2009
Mark Chapman
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
steves_here
steve
  • 1692 Answers
SOURCE: where can I find a free service manual for a mercury 15 hp outboard
Hi Timmy, The links below are for a free service manual for a mercury outboard 2 stroke motor... CHEERS..
http://www.baads.org/wp-cms/wp-content/uploads/2013/10/Mercury_2-stroke_manual_PART1.pdf
http://www.scribd.com/doc/18149131/Mercury-15-Manual#scribd
Posted on Mar 31, 2016
Bill Boyd
  • 53816 Answers
SOURCE: Where might I find a working fuel pump for a 1966 Mercury 3.9 hp outboard motor?
there is a pump for sale on e-bay --seller is western furniture (1918) used condition for $25.00 us 2 people watching it but it has a buy now tab
I found this by going google and typing in --fuel pump for mercury outboard motor 3.9 hp-- and the site is www.ebay.tv>sch>ebay-motors-
mariner is also a part of the mercury range so check for mariner 3.9 or 4 hp parts
Posted on Sep 11, 2016
How much does a 1996 Mercury outboard motor 115 hp weigh
FourStroke 150 hp - Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/75-150-hp/Mercury FourStroke outboard motors are incredibly powerful and efficient, and they feature a wide range of applications. Crafted for less weight and high displacement, they generate abundant torque and immediate power. ... 150 115 90 75. HP / kW‎: ‎150 / 110
Engine type‎: ‎8-valve single overhead cam ...
Dry weight *Lightest model available‎: ‎455 lbs / .
Jun 13, 2018 | Mercury Boating
What is the fuel to gas ratio for a 7.5 mercury outboard (1975)
Fuel and Gas is the same thing :>)
You mean fuel to oil ratio? 50:1
The 7.5 hp Mercury outboard requires a 50:1 ratio, one pint of 2 cycle oil, to six gallons of fuel.
mercury 7 5 hp outboard fuel mixture Google Search
Use Evinrude XD50, as it is by far the best and has less fumes.
Evinrude XD 50 2 Cycle Oil 2 stroke
Apr 18, 2018 | Mercury Boating
Looking for a 2016 tracker targa V 18 combo with a 150 HP murcury 4 stroke outboard engine owners manual
Manual is in the first link
Mercury 150 FourStroke Manual
https://dmna.ny.gov/nynm/manuals/Mercury_150_FourStroke_Manual.pdf
RCD-H-2 Rev 4. 150 HP 4-stroke (3.0L) hp. OP401000 or. 1B227000. RCD-H-2 Rev 4. Essential requirements. Standards. Other normative document/ method ... Owner's manual. This declaration of conformity is issued under the sole responsibility of the manufacturer. I declare on behalf of the engine manufacturer that the ...
Owner's Resources ' Mercury Marine
https://www.mercurymarine.com/en/au/service-and-support/owners-resources/ The major consideration in preparing your outboard for storage is to protect it from rust, corrosion and damage caused by freezing of trapped water. Outboard Storage tips ... Mercury Authorised Dealers have the expertise and training to handle all of your engine maintenance service and needs. Engine Maintenance.
FourStroke 150 hp ' Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/150-hp/ The specifications displayed here may not be indicative of the entire engine family; click on the "See All Models and Specs" link to view the specs in detail. ... Perfect for Repower. The compact, lightweight design of the Mercury® 150hp FourStroke engine fits most transoms, including those with narrow engine wells and tight ...
Outboard Care ' Mercury Marine
https://www.mercurymarine.com/en/ca/landing/outboard-care/ Step-by-step videos to help you maintain your 150 hp FourStroke. Flushing; Oil change ... This helpful how-to video shows you how ensure your outboard motor is maintained for peak performance. Here are step-by-step ... FourStroke engine. For more information, please consult your Mercury Marine owner's manual.
150 HP Mercury 4 stroke outboard engine owners manual Google Search
Dec 06, 2017 | HP Boating
Sep 11, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Boating Logo
688 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
ray gallant
Are you a Mercury Boating Expert? Answer questions, earn points and help others
