Question about Fishing
My reel won't lock, it spins in both directions
Posted by Lorri Nelson on
Duke Mcadams
    Habit-Forming:
    New Friend:
  • 11 Answers
Flip the switch in the back or front of reel rather towards bottom one makes it click when you real with an anti reverse brake
Posted on Oct 12, 2017
Chris Huff
    Top Expert:
  • 6,289 Answers
There should be a lever or slide on side or underneath reel body that engages lock.
Posted on Sep 05, 2017
Steve P
  • Fishing Master
  • 3,712 Answers
1 Related Answer
David Shaub
  • 2976 Answers
SOURCE: Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Posted on Feb 20, 2009
Why is my reel able to reel both directions instead of locking in place?
Sounds like the slider switch didn't get back into it's socket properly, take it back apart and look at that.
Jan 31, 2015 | Abu Garcia 7000i RED Baticasting Reel
My reel wont lock
There are only a few things it can be, either the gear that kicks the kick lever back is not seated correctly or there is an issue with the kick lever itself, email if you would like it repaired [email protected] names Neil
Apr 10, 2013 | Generic Hurricane Mako Spinning Reel
Does not flip arm to lock to reel in line
Normally when you **** the bail, the reel allows you to discharge the line with a flip of the wrist. Then when you touch the crank and execute half a turn it releases the bail to lock the line and allow you to reel in. If this action is not happening, then the release pawl is stuck and holding the bail in place. You must disassemble the reel, clean the parts and re-assemble with proper lubrication. Checking the parts for wear replace all worn parts.
Jun 22, 2011 | Shakespeare Agility Spinning Reel 6825
What is the lever at the back of a spinning reel for?Its located at the back on top
The lever on the back of spinning reels is an anti reverse lock. It is used to prevent the reel from being able to wind backwards or for allowing it to depending on the position it's in.
Jul 26, 2010 | Shakespeare Agility Spinning Reel 6825
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Fishing Logo
4,354 people viewed this question
Top Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Fishing Expert? Answer questions, earn points and help others
