Food Processors Logo
R
Rosemary Willing Posted on Aug 27, 2017
Have lost the spindle to. Put blades on my Russell Hobbs food processor model no Rhfp 600 . Do you have the. In stock
5 Related Answers
A
Anonymous
  • Posted on Jan 24, 2008
SOURCE: stuck sunbeam blade on spindle
Put some water in it and run it for a minute or so. That helped me with the same problem on the same processor.
Anonymous
  • Posted on Oct 22, 2008
SOURCE: Wolf Gang Puck 620 Food Processor - Broken Blade - Need replacement
You guys with the Wolfgang Puck processor, need to go to this website, they have what you need but not what I need, I need the spindel, the blade is $9.99 www.wpcookware.com
Anonymous
  • Posted on Nov 16, 2008
SOURCE: chopping blade # 70207
customer service number 1-877-207-0923 for hamilton beach
Anonymous
  • 10865 Answers
  • Posted on Mar 18, 2009
SOURCE: where can I buy repair parts for food processor
Call 1-800-851-8900 and order what you need directly from Hamilton Beach.
Please mark this as a fixya! thanks
Anonymous
  • Posted on Aug 30, 2011
SOURCE: need replacement blade for hamilton
need replacement blade for hamilton beach food processor replacement model 70450
Do you have replacement bowls for Russell hobbs food processor ?
Hi Josephine:
Fixya is not a retail store that actually sells stuff.
We mostly give free advice.
Soooooooo.....
I'd suggest that if you can't get the bowl you need through whomever sells the units, you could try checking with a thrift store (such as the Sally Ann or local hospital auxiliary) to see if you can find the appropriate sized bowl.
Cheers
I have a salton food processor model #FP-25 and I need too replace my lid. Can you help me
This was manufactured a number of years ago by Salton, Inc. which changed its name in 2009 to Russell Hobbs, Inc. which was then purchased by Spectrum Brands in 2010. Typically these low-end consumer products are not carried for more than a couple years and finding parts after these company changes is unlikely.
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Russell Hobbs RHFB 044
Where can I get the manual for a Russell Hobbs processor RHRB 044?
4helpful
I used the shredding blade and now can't get the inside spindle to pop off or the bowl. It will still work if I put the blade in and turn it on. How can I get the spindle and bowl loose?
I posted about this somewhere else. Sounds simple but it worked for me. Give the spindle a good whack with a wooden spoon all the way around and it will come loose.
12helpful
2answers
Magimix sytem cuisine
Stuck sunbeam blade on spindle
Top Russell Hobbs Food Processors Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Russell Hobbs Food Processor Expert? Answer questions, earn points and help others
