Question about Hobart Dishwashers
Hello experts, My problem is Hobart Dishwasher FXL - 70N. Really good mashine but now we have a problem. It doesnt want to work :D
Problem start few weeks ago. In the morning I press Play to warm up the mashine. it takes 10-15min to warm up.As it gives me green sign i put dishes inside and press again Play. process start. I can hear Click sound, the pump is taking soap, but there is no water, the props are not rotating. program is taking time as normal, to finish ciclus, and it stops normaly. like everything is fine. when I open the door, I can see that there is no water, and dishes are still dirty. Please help! thanks in advance. Ivan Ratkovic Montenegro
Posted by Ivan Ratkovic on
myrlanthian
    Sergeant:
  • 250 Answers
Wash tank air trap blocked?
Posted on Jan 06, 2018
5 Related Answers
Anonymous
  • 105 Answers
SOURCE: Have the Kenmore Limited Edition
check the wash arms to see if food has not cloged the holes stopping water getting through
if these are clean the machine may not have enough water entering machine
also check how you stack machine
Posted on Feb 02, 2008
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: Miele dishwasher troubleshooting
either your heater is broken or spray arms are clogged.
Posted on Jun 02, 2008
Anonymous
SOURCE: Kenmore Dishwasher does not wash
my problem is the motor hummms for a minute or so and turns off. Could this be the capacitor? how do you test a capacitor?
herb
Posted on Jul 14, 2008
Anonymous
SOURCE: water not going in
This is a little late for the OP. But, I had the same problem over Thanksgiving of 2008. I searched online and saw that other people had the same problem, but there were no solutions posted. So, I paid $130 for a service tech to come fix the problem - maybe this will save you some time and money.
The solution was simple...pour boiling water (I boiled about a half gallon of water in a cooking pot) straight into the pump where the water sprays out of. You don't have to pull your dishwasher out and no tools are needed. Just open the door, pull out the lower roller tray, remove the bottom spray fin (just pull straight up), and pour the boiling water straight into the hole where the bottom spray fin was attached to. Next, put everything back in place, push the Power switch on, select a wash mode, and close the door. The dishwasher should start spraying water inside as usual.
The service tech told me that there are only two pumps in this dishwasher...one to pump the water in (the one that had the problem) and one to pump the water out. When you don't use the dishwasher frequently, the seal in the wash pump seizes up (sticks together). You can hear the motor humming, but the pump isn't able to send the water up into the spray fins. By pouring boiling water into the pump, it helps to break that stickiness and allows the pump to start sending water up into the spray fins. The solution is to run your dishwasher at least once a week. Even if you don't have much to wash, run a rinse cycle to let all the parts move and stay loose.
One other tip the tech told me is to pour a cup of white vinegar into the pump when you go away on vacation and the dishwasher won't be used for a week or more. This should keep the seals from sticking together. I haven't tried this yet.
Hope this helps.
Posted on Dec 28, 2008
Anonymous
  • 98 Answers
SOURCE: Dishwasher only heating water - blades not turning, no new water
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic by Make and or problem...hope you find this helpful :-)
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Posted on Apr 01, 2009
I have a Hobart LX18C. New control board now turns on, but it says "18H" when it starts up and shows a P3 error code. I think it's confused because it's a C model (low temp) not H (high temp).
Error P3, Rinse Tank Booster Thermister is faulty
SOLVED: Hobart LXI Dishwasher a P3 code is flashing ...
https://www.fixya.com > support > t4318217-hobart_lx...
Mar. 11, 2010 - It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you ... 1 answer · 11 votes: The p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ...
SOLVED: What is p3 code on hobart am15 dishwasher - Fixya
Sep. 2, 2019
SOLVED: What does a P3 code mean? On a Hobart LXI high ...
Jan. 5, 2014
My hobart am15 display a p3 error code and i make - Fixya
May 1, 2010
SOLVED: Error code "p3" appears in the digital panel with a ...
May 12, 2010
More results from www.fixya.com
18H doesn't exist
https://www.google.com/search?q=hobart+lx18c+18H+error+code
1helpful
2answers
Hobart dishwasher LXIH starts filling and stops after 5 seconds or so
Hobart is probably the most user friendly manufacturer out there. Their service manuals are great. Try this.... Good luck Manuals Support
Hello sir i have got hobart dishwasher it doesnt run but it rinse what shall i do it
Possible that the program controller unit is faulty. The outputs to the motor must be checked during the wash cycle and if it is absent even after water has filled in then the controller unit can be faulty.
Dec 11, 2010 • Dishwashers
Backflow - want to be charged by council to monitor
All Hobart AM-14 come with a vacuum breaker which prevents any back flow from occurring.
Regards
2answers
Parts for a AM-8T2 ?
Hobart discontinued this machine prior to 1970. I know for a fact that there are no parts available. I would recommennd an new AM14 or a AM15 model
Dishwashers Logo
Top Hobart Dishwashers Experts
vestxre
Oloyede Monsuru
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
