Question about Tamron Cameras
Greeting, I have a D200 and about to use the Tamron 200-400 Telephoto lens for sports. How do I setup my settings to get best shots!
Posted by Bernard Hamilton on
Tony Parsons
  • Tamron Master
  • 6,316 Answers
Use the settings that will give you the best exposure / shutter speed / focus
Posted on Aug 27, 2017
5 Related Answers
Anonymous
  • 480 Answers
SOURCE: will not autofocus
Hey shutterbug72,
According to the manufacturer the first thing you should try is cleaning the lens contacts with an eraser. If that doesn't work you could try removing the battery and reinserting it to reset the camera. It seems to me that if there was a compatibility issue going on you should have seen that from the start. As far as what lens you should buy both Tamron and Canon make very good lenses, but with Canon lenses you shouldn't ever have compatibility issues. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 23, 2008
Anonymous
  • 423 Answers
SOURCE: Adding a telephoto lens
Try zooming in. That usually gets rid of the "vignetting" you are experinecing.
Posted on May 26, 2008
Anonymous
  • 17 Answers
SOURCE: New Camera
Get the Canon EF 70-300mm IS USM about $500 and EFS 17-85mm IS USM about $300. The 75-300 all of them I would not use them 4 a body cap. Camera is fine or step up to XSI.
Posted on Jun 14, 2009
Gary Maitland
  • 117 Answers
SOURCE: blured zoom shots due to low light
Hi Charles A/f works on contrast it 500mm f6.9 even at 1600 iso it willl make no diffrerents if it to dark it will not lock on
Posted on Aug 08, 2009
Anonymous
SOURCE: when i use my 17-35 tamron lens on my d200 nikon
Hi. I had the same issue when I first got my D200 years ago and just happen to come across your post. It is a simple adjustment in your Bracket/Flash mode in your menu under e. Go to (Manual Mode Bracketing) and set it to (Flash Only) and then the F-Stop wont jump around on its own Hope this helps you out.
Posted on Sep 04, 2009
What is T Mount Telephoto Zoom Lens with 2x Teleconverter
The T-mount is a universal thread developed by Tamron which allows various adapters to couple a lens to a wide variety of camera brands. If a lens is listed as having a T-mount, it means that the lens can be coupled to your camera if you have a T-mount adapter for your camera.
A 2X teleconverter (often called a doubler) enables a lens of a specific to be doubled. For example, the lens referenced above actually is a 650-1300 lens but with the 2X teleconverter the focal length can be doubled to a maximum focal length of 2600.
I have an Opteka 600-1200 telephoto lens which I consider to be a decent lens for its very low price. I also have a doubler which came with my camera kit. That means I can increase the focal length of my lens to 2400 but I cannot imagine any reason to do so. At it's full zoom 1200mm focal length, this lens is very difficult to handle and must be used on a tripod with a remote shutter release.
It is extremely time consuming to focus and must be focused very accurately because it has almost no depth of field. At 1200 mm, the slightest breeze or vibration will cause the picture to go fuzzy from movement.
The lens is also large and does not fit conveniently in a camera bag so it rarely goes with me unless I know for sure that I will need it. It is not particularly good for sports action shots because the action will be over before you are ready to shoot the picture. With very bright light (such as the mid-day sun) and pre-planning and pre-focusing you might be able to get some interesting sports action shots. Say you're at an automobile race and you know a car will be coming into view at a certain spot, you can set up for that spot then trip the shutter when the car pops into view.
All that being said, I think this is a good lens to have in my bag without spending $10,000 plus for a really good lens of this size.
Feb 08, 2013 | Opteka 650-2600mm High Definition...
Was I sold a 'pup'? Tamron lens box says AF55-200mmF4-5.6LD MACRO. Can't find macro setting on lens or instructions. Looking at your site, Product Details says 'No Macro'. So what's...
Excerpted from a www.photo.net review of the lens:
Though the Tamron AF 55-200mm Di II LD Macro has "Macro" in its name, it's not really a macro lens. Maximum magnification is about 1/3 life size (Tamron spec it at 1:3.5) as you can see from the following image below, which was shot at 200mm and at the closest focus distance (0.9m/37.4"). This isn't too bad, but it's more of a close focus telephoto lens than a "macro" lens (bolding for emphasis added).
Sep 09, 2011 | Tamron 55-200mm f/4-5.6 Di-II LD for Canon...
Is tamron af 35-90 compatible with nikon d200?
Tamron makes lenses with a variety of mounts. Assuming the lens has a Nikon mount, then it is fully compatible with the D200.
Aug 05, 2011 | Tamron AF 35-90 f4-5.6 for Nikon AF
Using 200-500 Tamron on Nikon d300. When I shoot, camera freezes. Clock and exposure readout next to it, on top panel, blink. Camera will not turn off, I have to take the battery out. Lens works...
Maybe there is something wrong with your batteries? Replace them. I had the same experience with my D200 and a Nikon 18-200 lens, later with my Nikon 10.5, Sigmaa 135-400. After replacing the battery everything worked as ever.
Mar 26, 2011 | Tamron 200-500 F5-6.3 DI AF Lens Nikon
I cant seem to get the lens to fous on anything within 3 feet when in macro.. am i doing something wrong?
Actually you are doing really well cause the Tamron specifications for that lens is 1.5m translated into real numbers that's 4.92 feet. If you want some serious macro let me suggest the Canon 100mm F2.5 Macro lens it's not all that bad for price unless you get the IS version then it's out of the park well sort of. Most of my macro work is done on a tripod anyway so the IS is a waist for me.
Here is a review on that lens.
http://www.fredmiranda.com/reviews/showproduct.php?product=47
Also is you are using the APS size sensor there is a focal factor of 1.6 so the 100mm lens just grew to 180mm and twice as fast as your Tamron. Cheers
Jan 07, 2011 | Tamron Zoom Telephoto AF 70-300mm...
When i use my 17-35 tamron lens on my d200 nikon on manual, the fstop jumps around on it's own. I'm not changing it. Also, as I'm taking pictures, for example if i take 5 pictures in a row in the same area...
Aug 01, 2009 | Tamron Cameras
New Camera
Jun 10, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
I need a manual for Tamron Camera Lens 28-200/3.8-5.6
You didn't supply what kind of Tamron lens it is. I'm gonna go ahead and give it my best shot on a guess: Tamron 28-75mm f/2.8 XR Di LD Aspherical (IF).
If I'm correct, you can download the manual here: http://www.tamron.com/assets/pdfs/A09.pdf
Hope this helps!
/Chris
Jan 17, 2009 | Cameras
Purchase Zoom Lenses
Canon currently makes super Telephoto lenses from 300mm to 800mm and a number of zoom Telephoto lenses from 28-300 to 100-400. You can also special order a 1200mm lens from Canon at a cost of $99k! (There are only about 20 such lenses made so far.)
You can also get a 1.4 or 2x teleconverter to further increase the power of a telephoto lens. However, the cameras are unable to auto-focus when the minimum f-stop exceeds f/8, which can happen when you use one (or both) of the teleconverters on these longer lenses, so you have to manually focus the lens.
You can also get telephoto lenses from other manufacturers such as Tamron and Sigma that are built to work with Canon cameras. However, the Canon lenses are generally regarded as the best quality.
Dec 21, 2008 | Nikon D70s Digital Camera
Cameras Logo
Top Tamron Cameras Experts
Steven Wander
Steven Wander
Harrie
Are you a Tamron Camera Expert? Answer questions, earn points and help others
