Hi
Your did not provide any info on which card you have or wish to install;
USB, PC Card, or internal mini
PCI card.
For mini
PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the
antenna cables) then
power-up and install the software (drivers and utility).
For
USB and PC Cards, follow the device manufacture's recommended steps. Generally, for
USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have
successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or
wireless ad-
hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not s
can or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
