SOURCE: loss of sound
you can try changing the assigned channel.you should have to put the second T V on a certain channel like channel 72 or 68 or something like that.on the main reveiver you should go into the menu and poke around in the setting until you see a REMOTE ADDRESS option walk through the steps and change the channel that the second TV receives its picture on, you should shoot for channel 62-72.also make sure the hisense is set to a cable input.you can go into the menu on the hisense and go to your settings and change this .it will be on CABLE or ANTENNA.try switching those around.also did you have sound before coming out of the coax output on the hisense? if your not sure then plug a vcr into and make sure the TV is working with different equipment.GOOD LUCK!
SOURCE: Dish Network remote wont control tv2 on my dual tuner
Your problem may be as simple as having the UHF antenna on the back of the receiver moved closer to the second TV. I suggest pigtailling it. This is a job best left to a professional due to the different configurations that may exist and assuring you have properly made connections. If this is an ongoing issue talk with the CSC agent and refuse to pay the service fee based on your past issues with the system. There are many other possibilities that could be the cause but this is the most likely and least involved approach and I am 99.9 percent sure this will solve your issue. Thanks for using Fix Ya.
SOURCE: In single mode, my remote for TV1 works, but in
Your shared view is enabled. , press the menu button, then option 6 then option 2, disable shared view then select done. ( this can only be done in single mode) then go back to dual mode.
SOURCE: I disconnected the 322 to install a new TV1. TV2
You should have one line entering the home behind the TV1 attached to it there should be a device exactly as you saw outside. You will want the line from outside connected to the single port called in/out and the SAT port goes to the silver seperator. The two lines leaving the seperator attach to the SAT in on the receiver. The UHF poret on the device connects to the home distibution port on the receiver.
Thanks for using Fix YA.
SOURCE: Television cannot find channels in
It sounds like the Dish receiver is having a problem. Have you tried calling Dish to see if they can reset the signal to the receiver (the Dish box attached to the TV...)? If they do that and it still has problems they should replace the Dish Receiver at no cost to you.. That should resolve the issue.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Hi Tracy, my name is Mike Houston a Social Media Representative at DISH. With the TV2 remote working for both TVs, you will want to make sure the TV1 input on the receiver is connected to the TV cable (RCA or Coax cable) and TV2 input is connected to TV2 port on the back of the receiver. I will provide you our link explaining in more detail about connections. If you have any further questions I will provide you my e-mail; [email protected]. Here is the link I promised you: http://www.mydish.com/support/same-video-2-tvs
