Ok, this is an update to my question. I had 2 answers so far with the same service manual referenced. Thank you for that however I already have that service manual and unfortunately it does not have the information I seek in it. I did however find the OG owners manual for the 1988 Sea Ray Sorrento S-23 that this stereo is installed in. Here is what it says the radio wiring is. Thanks anyway for your answers. All Wiring is 16 gauge Brown is right speaker positive White is right speaker negative Yellow is right speaker negative Green is left speaker negative Red/Violet is power Black is ground
This is the best I can do for you. I don't see any free manuals on line. In fact, I am hard pressed to find this anywhere else. (Vintage Manuals in Indiana appears closed, although you see web references to it.)
Sony Service Manual for the XR 17 Cassette Player Radio Car Stereo Repair...
SOURCE: Sony Cassette Car Stereo - 10 disc changer - XR-C5120R/XR-C5110R/xr-c4120
NEED TO REMOVE POWER FROM UNIT THERE SHOULD BE A BLACK CABLE THAT GOES IN TO CHANGER REMOVE IT WAIT 5 SEC AND INSTALL BACK LIKE IT WAS AND THIS WILL CUT ALL POWER TO UNIT AND WILL 50% FIX THE PROBLEM
LET ME KNOW
SOURCE: default code for re-conneting sony xr-m510 cassette player
To input the code press the remote buttons, off,source,att and then open. This should reset the unit and allow access to the control's.
Cheers Ian
SOURCE: I disconnected the car battery
you need to take it to the dealer to have them reset the codein the radio. Unless you have the code, the dealership can reset the code and you can reset yourself a new code. You can also try any electrical shop that has the proper scanning equipment to unlock the radio codes. Hope this helps.
SOURCE: Sony Amplifier, Sony CD Player,
The actual task of hooking up a home theater may take a little time,
especially if you are doing a custom installation with lots of separate
components, but following 3 links have the basic principle of input and output...pls visit all and than you can easiliy connect all properly..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
The Basics of Home Theater:
Sample Wiring Diagrams
http://www.prillaman.net/ht_info_8-wiring.html
Home A/V Wiring Diagram
http://www.unicom.com/blog/entry/521
How Do I Hook Up My Home Theater?http://hometheater.about.com/od/hometheaterbasicsfaq/f/htbasicfaq7.htm
SOURCE: Stereo installation
Contact crutchfield and buy a factory interface cable. doesn't cost much.
