Question about Mercury Boating
If ignition attached to a dashboard fuses in behind dash board. should be marked. if motor is tiller steering then the fuses are inline or tucked in housing. back track from problem.
Posted on Oct 02, 2017
SOURCE: relay switch for power tilt for Johnson outboard motor 40HP
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
Posted on Oct 30, 2008
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
SOURCE: replace impellor in yamaha 2 cylinder 40hp
take all bolts out on foot were the two mate drop lower unit down pull impellar cover will be plastic some what roun with a short molded inlet on top when u remove impellar be sure not to lose the key way and when u put the cap on the impellar be sure to rotate it so blades will ben\d in place make sure u dont pintch them when u bolt the cover down MAKE SURE WHEN YOU PUT THE FOOT BACK ON TAT YOU LINE UP THE IMPELLAR INLET WITH THE ONE COMMING DOWN FROM THE ENGINE LINE UP YOUR SHIFTER LINKAGE (TOWARD THE TRANSOM IS WERE IT IS LOCATED bolt it up test with a hose should be good
Posted on Jun 27, 2009
SOURCE: Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at http://www.crowleymarine.com/mercury_parts/6995/240.cfm which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Posted on Nov 12, 2009
SOURCE: wiring diagram for 1982 Mercury 6cyl outboard tilt
go to ebay and buy a manual
Posted on Mar 27, 2010
Aug 20, 2017 | Mercury Boating
May 22, 2017 | Mercury Boating
Dec 01, 2015 | Boating
Jul 29, 2017 | Boating
Jun 04, 2012 | Boating
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
Jul 10, 2010 | Light Outboard Motor Boat Bass Fishing...
Apr 27, 2009 | Boating
Oct 30, 2008 | Boating
158 people viewed this question
Hi richard w jones, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Is it please possible to obtain your exact model and serial for identification of the right electric circuitry?
If its a Four stroke, you'll find in the frond of the engine (under the hood of course)a small black 'rubber' box with 2 red wires. Remove the cap, there is a 20amp (yellow) fuse in it.
On a 2-stroke, the fuse is in the vincinity of the electrical connector for the cable to the remote control. It's also a 20amp fuse.
