Question about Black Office Equipment & Supplies
Can I use 2 black cartridges instead of 1x colour And 1x black
Posted by Christine on
Bill Boyd
    Top Expert:
  • Black Master
  • 53,779 Answers
No point
the machine is programmed to use each colour as required
putting in black cartridges will still only use the one black cartridge
remember that grey is not less black but black with a colour mix
Posted on Aug 26, 2017
5 Related Answers
POSMAN
  • 48 Answers
SOURCE: why doesn't my hp photosmart c3135 scan in
The problem is the slot for a printer maybe is stuck with old tint maybe try to clean the catridge and clean the slot .
Posted on Nov 28, 2010
POSMAN
  • 48 Answers
sorry that printer need the black cartidge because is the principal, If don't have a black catridge it don't work. Please replace the black catridge.
rumorbill
  • 544 Answers
SOURCE: Can you use 2 black cartridge instead of 1 black 1
You would not be able to.
The cartridge front is different and would not fit.
Also it is a requirement to have the correct cartridges to print.
Posted on Jan 11, 2011
Testimonial: "Thanx,thought that would be the case."
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: sir, I hav canon ip1880
I would not advise doing that. Once you do this you could have unexpected poor print quality.
If you only want to print black documents then I suggest you purchase a laser printer, these printers are not expensive now and the cost to per page is cheaper than inkjet printers and they do not suffer from block inkjet nozzles.
Posted on Mar 20, 2011
Nicholas Renard
  • 93 Answers
SOURCE: How to save catridge? How
Go to properties of your printer and tell it to print in black.
Posted on Apr 13, 2011
Why is my dcp135c printing images in brown instead of black
Several probable causes of this.
  1. Your Black is empty and the printer is trying to approximate the Black using the other colours. Check and replace Black.
  2. Your Black printhead is blocked and all you are seeing is the other colours that are used to make the black into a full black. Check cartridge and do a printhead clean to see if this clears it. Also print off a print quality test sheet (In the Ink Management options on the printer)
  3. Another colour has been put into the Black Slot on your printer. Replace the incorrect cartridge and hope that the printhead has not been damaged by using the wrong cartridge. May need several printhead cleans to clear incorrect ink from the feed lines.
Hope this helps.
Oct 07, 2014 | Brother DCP-135C Flatbed Digital MFC...
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
Can you use 2 black cartridge instead of 1 black 1 colour in the HP all in one 2575 photosmart printer
Jan 11, 2011 | HP Photosmart 2575 All-In-One Printer,...
I have a hp 6500. It has started printing pink instead of black.
Either:
* printers mix in a bit of "colour" ink when you request BLACK,
so that the colour ink-jets do not dry-out. So, since your BLACK has become EMPTY, all you get is PINK,
or,
* some printers mix colours to produce BLACK-ish colour.
Check that your CYAN and YELLOW ink-cartridges have not gotten to be EMPTY.
Jul 17, 2010 | Office Equipment & Supplies
Printer is not printing black but in a pinkish color
Most printers use the colour cartridge to make black, instead of the black cartridge. When you go to print a black and white document, on the box where you choose the number of pages to print, click properties, and locate the colour settings. There will be two options: Colour/Black and White-with a sub option of high quality or black only. Select Black only. The printer will now only use the black ink.
Apr 14, 2010 | HP J3680 Officejet All In One Printer
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
There is no black ink in the printer but there is colour how do i get it to print
Depending on the type of printer you may be able to print all in colour instead of black/white. The easiest solution is to replace the black ink cartridge though.
Jan 14, 2009 | Office Equipment & Supplies
Printer only prints out in blue
change the color cartridge and instead of Black,,use Photo Cartridge..
Nov 01, 2008 | HP Deskjet 3845 InkJet Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Top Black Office Equipment & Supplies Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Lawrence Oravetz
Are you a Black Office Equipment and Supply Expert? Answer questions, earn points and help others
