Question about Sigma Cycling
I replaced the battery in a Sigma bicycle computer(BC 506). I need a manual to reset the wheel size and set/reset the speed, miles, time, total miles, time of day. Can you refer me to a pdf download?
Posted by Gail Schott on
Donald Ayers-Marsh
  • Sigma Master
  • 1,389 Answers
Google "sigma bc 506 manual" or contact Signma:
SIGMA SPORT
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Posted on Aug 26, 2017
2 Related Answers
Anonymous
  • 119 Answers
SOURCE: A code for 27inch 700 wheels for sigma bicycle computer needed
Dear spinnerrr
  • Multiply the wheel diameter in mm or cm by 3.14.
  • Measure the distance travelled in one complete turn of the wheel.
this is the four digit number you are looking, it should be between 2145 and 2149
Regards
Posted on Mar 28, 2008
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a sigma 506
Roll the wheel one revolution and enter the ditance in millimeters..
Posted on Sep 16, 2011
Turning off a sigma bc 506
Sigma bicycle computers go to sleep after a programmed time.
Jun 12, 2017 | Sigma Cycling
Sigma BC 1609 Cadence Bicycle Speedometer reads my movement much slower than I am actually going. E.g. moving about 15, reads as 5 mph.
I had the same problem. It is caused because the mount is facing the wrong direction and your computer is swapping speed and cadence. 5 mph would mean 63 RPM of the wheel which probably what your pedal is actually doing. The wheel is actually turning at about 3 times that rate so if you check your cadence it is probably maxing out at 180 even though that wouldn't be possible.
To fix this, just twist your mount 180 degrees on your handlebars or stem and try again. That way the computer is correctly lined up with the mount.
Mar 10, 2012 | Sigma Sport BC 1609 Cadence Wired Computer
Need help reseting for tire size 26x2.1 changed to road tires can't find my book it's a sigma bc 906
you can measure your wheel by placing your bike on a flat surface with the valve stem on the wheel in the bottom most position or 6 o clock position. mark the floor where the valve stem is. now roll the bike forward so that the wheels gets one full revolution and the valve stem comes back to the 6 o clock position and mark the floor at the valve stem. now get a tape measure and measure the distance between your two marks. Convert this measurement to usually centimeters. that will be the number that put into your computer.
the manual can be downloaded here
Rick
Bicycle Parts and Accessories
Jul 03, 2009 | Sigma Bc 906 Computer
Cycling Logo
811 people viewed this question
Top Sigma Cycling Experts
Michael Thomas
Michael Thomas
John Long Shipton
Vincent G
Vincent G
Are you a Sigma Cycling Expert? Answer questions, earn points and help others
