SOURCE: Hampton Bay Ceiling Fan 476-317
you will have to order this switch direct from hampton bay
or one of there dealers
http://www.eceilingfans.com/switches_-_pull_chain_-_ceilin.html
this is the link needed shows what the pull looks like print out the page match with your wires in fan
this is there home link with phone number for ordering parts
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
SOURCE: 3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need. Hampton Bay is the Home Depot brand.
SOURCE: I can't find a replacement fan 3 speed switch for
Hi azwaverid!
I just had a similar problem with my ceiling fan, not sure if I have the same model as you (the fan was in the house when I bought it). I do have the exact same pull chain switch (K.T.E 2035080).
I went to a big home improvement store and the salesman gave me some 3-way switch and guaranteed it would work. The switch had only 3 wires, not 4 like the original. Can you guess what happened next? That's right, their part didn't work.
Being an engineer, I could not admit defeat. I consulted with other engineers I work with, and they pointed me to a "mom & pop" electronics store close to my house. I went to Centennial Electronics in Colorado Springs, CO. The sales staff didn't have experience with this problem, but at least helped me and offered suggestions.
I ended up buying a Philmore Pull Chain Switch for $2.51 after tax. This worked perfect! Just be sure to place the wires in the right slots. On my fan, the following positions and wire colors were: L - Orange, 1 - Yellow, 2 - Purple, and 3 - Blue (I just matched them up the same as the K.T.E. switch colors & positions).
Hope this helps!
Bob
P.s. The exact part I used was:
Philmore No. 30-9152 (UPC code: 0 38975 39152 6). The box says (everywhere you see a semi-colon is a line break): Philmore PULL CHAIN SWITCH; L-1-2-3, L-2-3, L-1-3, L-1-2, PUSH-IN TERMINAL; 6A-125V AC, 3A-250V AC; Made in Taiwan No. 30-9152; LKG Industries - Rockford, IL
