SOURCE: Returning router
First, as a previous warranty tech that did a lot of work with HSN computer products, I do not give them very high grades for ease of use, or top notch products..... JMHO...
The website sure does not give you much:
Q. Is there any merchandise that is not returnable?
A. Non-returnable merchandise would be 80% -90% off clearance and or Final Sale merchandise and "tax exempt" purchases. Merchandise purchased from the HSN, ON-Air show or HSN.com cannot be returned at the HSN Outlet Stores.
Here are the return instructions (note the telepone number):
Just follow these return instructions:
SOURCE: I accidentally ordered 3 ipod touch's from Amazon.
You can check all this in your amazon account and you can return goods once there not opened and returned within 30 days.
SOURCE: Please help me to return a book which you sent two
No problem, just contact Amazon.com customer service and they will give you an RMA number. Not sure why you are in our forum.
SOURCE: above 78F no longer works
Your head pressure is a little high, depending on the ambient temp and your suction pressure is a little low. The suction pressure should be around 68 psig, the equivalent of a 40 degree coil. You can try adding a little refrigerant, check your compressor amp draw. If head pressure keeps going up and suction doesn't come up you may have a restricted metering device or filter dryer
who made the error ,
if it was within 14 days yes
if they made the error YES
