Need manual to shut red light off on front door left side next to energy saver
SOURCE: Energy Saver
Turn Power off, hold down the 8 & 0 keys while turing power on. Enter 11, depress start, enter 1, depress Interupt, hold down 0 & 9 keys and you have disabled Energy Saver
SOURCE: Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent. Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me. It will be too expensive to repair, so I am dishwasher shopping.
SOURCE: wHIRLPOOL SIDE BY SIDE fridge GD25DFXFW 10 YRS
Get your refrigerator repainted before it is too late. It isn't that costly. Cracks may be due to rusting. Ask those mechanics about it when you give it for painting.
SOURCE: hot spots on door and side of frig
www.viewpoints.com/Samsung-RS2630SH-review-fe12- HELLO, what is taking place is resistance is building in these areas because you have strip heaters in the doors on the freezer and refrigerator door. This keeps any moisture from turning to ice. There is not a lot that you can do or that I can lead you to do with this going on. Some heat is normal as they are heaters. But, if these spots are hot to the touch, being that this is a expensive and new box, I would call the manufacture and ask questions to satisfy you. I would not worry about this unless it is to a point to where you can't touch it, smell any electrical or burn smell, but not to worry as they have many safety controls to keep anything from burning up as I didn't want to scare you.Some units use hot freon liquid or gas that runs through coils in the freezer to keep ice from building up. I have done some research on this model, and it is a very common complaint from new owners. The factory is saying as I said not to worry, a normal condition with this unit. If you start to loose any cooling in either compartment, to call them. I added a link for you on this unit as there seems to be a lot of complaints on this model. I pasted it at the top, so I hope you read my info before going there. Please keep me posted on the outcome and I wish you the best
Sincerely,
Shastalaker7
