Question about Hotpoint Refrigerators
Hotpoint htm17bbssa fridge not cooling but freezer works
Cleaned off coils, but refrigerator still not cool enough
Posted by Joseph Intrabartolo on
Marvin
    Top Expert:
  • Hotpoint Master
  • 85,239 Answers
Check the air distribution door from proper operation
Posted on Aug 25, 2017
5 Related Answers
Anonymous
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: The fan is running, but the refrigerator and freezer are not cooling. We cleaned the coils... any other suggestions?
Check the compressor and the relay. Make sure they are working when you turn on freezer and fridge to the max. If the compressor does not start then you need a new relay. If the compressor starts then it is your thermostat that has gone bad and must be replaced. you can find the parts on repairclinic.com and order them with instructions on how to remove the bad part and install the new part
Posted on May 20, 2009
Sal De
  • 2699 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
Anonymous
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: [email protected]
MANY THANKS
Posted on Mar 01, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Hotpoint refrigerator side by side
All of the cold air for the refrigerator comes from the freezer. Is there any ice build up behind the shelves in your freezer?
Feb 28, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Got a hotpoint ff72 fridge freezer and the fridge is not working, light still comes on but fridge is warm. freezer is ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Hotpoint Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
FRESH FOOD SECTION OF SIDE BY SIDE FRIDGE NOT COOLING ENOUGH. TEMP SET @ 9. FREEZER SECTION WORKING FINE
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Hotpoint HSS25GFP Side by Side...
My hotpoint top freezer is not cold enough. The ice creams are all melted. I don't see any knob at the top for adjustment. There is a adjustment a the fridge level. I already turned it up to the hightest...
Let the level be set at midpoint and for a start put the fridge off for thsystem to come to normal , the compressor to reset. Now draina nd clean all the cooling coils inside the freezer unit. Look for visible wearing off wires or connection in the temperature sensors. Check lines to the timer, heater and the thermostat. remove panels to check . now clean the compressor contactor and aster all the panels are put back, restart the fridge. If the cooling returns then you willhave to wait and watch if the timer works to auto deffrost. if not replace. If the cooling is still bad then you must check for hte weeakness of the compressor, low pressure of gas. service and refill gas but I would recommend with a good help. Get extimate before you start he work and ask for time warranty for the work. Hope you work this out. Good day
Jul 31, 2010 | Hotpoint HTS16BBSL Top Freezer...
GE Side By Side top portion of fridge and freezer not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge part of fridge freezer not cooling
heatman101
Aug 16, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Refrigerators Logo
Top Hotpoint Refrigerators Experts
jdthefixer
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
