SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
SOURCE: Control board reset?
Amana
version of adaptive defrost : Press
refrigerator light switch five times in six seconds to initiate defrost cycle.
Pressing five more times within six seconds will cancel defrost and go straight
into the run mode. Similar operation on both bottom mount and SxS refrigerators.
After the defrost terminator/thermostat opens, six minutes of dwell time occurs
before the compressor and condenser fan motor will operate. After defrost
terminator/thermostat open, 10 minutes of dwell time occurs before the
evaporator fan motor will operate.
SOURCE: Refrigerator cold but not cold enough. freezer
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
SOURCE: frige not cooling, freezer is fine
its the problem of defrost timer.due to this the cold air from freezer section is not getting in to refrigerator section and its getting warm.check out the defrost timer.located beside the compressor at the back lower side of the unit.the cost of new defrost timer is near to $40.and you can get it from
www.repairclinic.com
thanks.
SOURCE: blowing cold air but not cold enough to keep frige cold
IF there is frost on the back wall inside the the freezer section about 12 inches from the bottom , you have a defrost problem . If there is no frost on the rear wall , then you probably have a bad overload/relay (part # 2188840 ) . This piece is the part which is plugged onto the compressor , with 2 or 3 wires going to it . Unplug it from the compressor and shake it . If it rattles , replace it .
