Cell Phones Logo
W
Wendy Posted on Aug 24, 2017
What would make a galaxy j7 lock up, or do a factory re-set on its own? I'm not able to find someone that knows how to fix it. my e-mail address is Wenharry25
My galaxy j7 is locked up and I'm not able to use it. I've only had the phone a few months and for some reason, it locked up. I'm not able to find anyone who knows how to fix it. I need help...please. Reply to 505-480- the number of the one locked is 505-480-
5 Related Answers
Anonymous
  • 101 Answers
  • Posted on Aug 03, 2008
SOURCE: Nokia 6234, PUK code locked...
PUK code is an eight digit code which we get along withe the simcard. if you dont have that code. please go to your network operator.
Anonymous
  • 1734 Answers
  • Posted on Feb 19, 2009
SOURCE: i have ht c diamond phone i want airtel live settings
Just ask at http://chinamanuals.com - they have manuals and MMS/GPRS settings for all providers.
Anonymous
  • Posted on May 29, 2009
SOURCE: Need Yahoo email remote access settings for Metro PCS phone
merci boko
Anonymous
  • 11967 Answers
  • Posted on Sep 27, 2010
SOURCE: The error is Lens error, restart camera. If
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Anonymous
  • 251 Answers
  • Posted on Nov 02, 2010
SOURCE: please....could anyone can help me
you CANNOT retrieve your lock code but instead, try to go to www.theunlockspot.com to have your free unlock code for your phone model.
Trying to get code to get back in my locked galaxy j7 v after restarts,did a factory and hard reset and can't get code or sign in through google
do a 3 finger hard reset.
press volume up
power button and
home button at the same time.
it will give you erase data and erase cache option. use both.
I am sure you will be fine. change passwords on your computer and everything.
2helpful
Need help with my sch-s738c Samsung phone . android come on telling me to reboot
Kenny, May have to rest, links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung Galaxy Centura hard factory reset
Global Download Center
HOW DO HARD RESET MY SAMSUNG SCH S738C Im locked out of my samsung sch...
Reboot samsungsamsung galaxy indulge stuck on samsung logo at boot up
1. Turn the power off first
2. Slide out the keyboard
3. Power on and press ad hold the 'R' Key
4. In Android system recovery use Vol keys to scroll up and down
5. Use the power key to make a selection.
If you cannot get to a recovery you will need to use ODIN to flash phone to factory state. this "should" fix anything unless phone itself is bad. Here is a ODIN guide for your phone. ODIN is official samsung flashing tools available for free from samsung. Good Luck.
http://theunlockr.com/2012/05/18/how-to-get-the-samsung-galaxy-indulge-r910-and-r915-back-to-stock/
On which pc suite does samsung pop works?
Dear Sir,
Welcome to Fixya Support. We are happy to assist you.
Samsung POP works with Samsung PC Studio 7.You can download it from their website.
Download Samsung PC Suit
My samsung ipod model yp-u3 need software to download songs, where i can find
Please check this link below for help:
www.ptf.com/???samsung/???samsung+ipod+yp+s3+software
www.dl4all.com/search/???samsung+ipod+software.html
1helpful
2answers
How to format samsung c5310
????? ????? ???? ????? ??????? c5310
Sep 27, 2010 • Cell Phones
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
