SOURCE: cant get pased language select screen
If you can work the controler try moving back a bit it wont work really close up if it still doesnt work take the controller back it could be damaged
SOURCE: Ipod 4th gen nano is frozen on the language selection screen.
That could be one of two problems: Either the cord of the click wheel has been disconnected from its socket which will be an easy fix and you only have to pay labor, or you may just need a new click wheel which should still be cheap.
SOURCE: Language on tomtom
You find Change Language from the Preferences menu from the main menu. You may need to switch on Show All Menu Options in order to see it. Again, this is from the Preferences menu.
SOURCE: Can not get past language screen
We had the same issue. Select your language first by pointing the controller and hitting the "a" button. Then, point the controller down to the bottom of the screen. There is a "confirm" or "OK" at the bottom right of the screen that you can't see.
SOURCE: Wii problem - Can't get past Select Language screen
keep getting a error has occurred,press eject button and remove the disc,then turn wii console off and refer to manual cant get past this.
Hi
You did not mention which gps systems do you have. Anyway giving you details of tom-tom gps language change instructions.
Change the language settings on your TomTom GPS device. If your TomTom GPS receiver is set to the wrong language, change the current language to the language of your choice. Perform a reset on the device as described in Step 1. When your GPS unit turns back on, tap the button in the lower right corner of the screen to continue. Tap the next screen to access the GPS receiver's main menu. Tap on the wrench icon to access the "Change Preferences" setting screen. Scroll through the "Change Preferences" screens until you see the "Change Language" icon, identified by three flags. Tap the "Change Language" icon and choose your desired language from the list. Depending on which language you chose, you may be asked to choose a new voice for turn-by-turn navigation.
For Garmin device:-
Try this below
Touch the Wrench icon which is located on the screen with the Magnifying Glass and Map icon
Touch the down arrow
Touch the Lips/Mouth icon
Touch the top right blue box
Touch the up arrow until you see American English
Touch American English
Touch OK
This should now be in English.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
