SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
SOURCE: error code e40 on my washing machine electrolux
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
SOURCE: e 20 error code on electrolux inspire washing
e20 usually means not draining...check for blocked filter, or obstructed/ faulty pump unit...
SOURCE: how to reset my washing machine (electrolux)
my electrolux EWT606 will not spin. it drains and then just wont go into spin cycle....no error messages it just beeps. can anyone help me please as i have kids with disabilities and NEED to wash!
Hey Desmond, thank you for your inquiry!
From my understanding your Electrolux washer is displaying an error code of 33. I am showing that is an invalid error code. This could be a miscommunication within your control panel. I would suggest performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. If the reset does not help correct the issue and the error code comes back please comment back. Also, let us know your model number. You can locate the model number of the door frame of your washer. Once I have that information I would be able to assist you further. -Matt
