Question about Panasonic Car Audio & Video
Panasonic car stereo wiring diagram for model CQ-DF203U
Posted by Norlito on
richie46
    Top Expert:
  • Panasonic Master
  • 12,962 Answers
Go to web site for unit's manual . It will have the wiring schematic for you.
Posted on Aug 23, 2017
Dennis Maeder
    Sergeant:
  • 257 Answers
You will find pinouts and installation related wiring in the manual around p 50-53.
For the manual see ftp://ftp.panasonic.com/caraudio/om/cq-df583u_en_om.pdf
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Posted on Jun 20, 2007
Anonymous
SOURCE: wiring
I HAVE ONE SCREEN LANZAR SVTV7R, I NEED THE POSITION AND COLOR WIRING OR DIAGRAM ELECTRIC THE CONECTOR. THANK YOU.
Posted on Nov 29, 2008
Anonymous
  • 10 Answers
SOURCE: CQ RDP162N
i can get a general wiring diagram for now need to look into it sum more
Typical Head Unit Wire Harness Function Typical Wire Colors Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Posted on Dec 31, 2008
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: car stereo installation diagram
Luckily most aftermarket wiring is standardized.
Try this...
P o w e r Memory (+12v Constant) Orange (Could Be Yellow) Ignition (+12v Switched) Red Ground (-) Black Illumination Yellow (could be orange) Phone Mute Yellow/Black Power Antenna Blue S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) Green Left Front (-) Green/Black Right Rear (+) Gray/Red Right Rear (-) Black/Gray Left Rear (+) Green/Red Left Rear (-) Black/Green
Posted on Jan 08, 2009
Jaime Hernandez
  • 2337 Answers
SOURCE: panasonic cq-dpx152u wiring diagram
Click here to download the user's guide and go to page # 28 for the wiring connections.
Posted on Mar 11, 2009
Wiring diagram panasonic cq c100u
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Wiring diagram to many popular car audio systems are given.
Jul 19, 2014 | Panasonic Cq-c1101u In Dash Cd Player...
LOSE MEMORY WHEN I TURN KEY OFF PANASONIC C Q DF203U
You need to make sure the yellow wire is going to a constant power source. The yellow wire controls the memory and needs power going to it even with the key off. Yellow is constant and red is switched or ignition.
Mar 16, 2012 | Panasonic CQ-DF203U CD Player
I need a wiring diagram for a Panasonic CQ-VD7001U car stereo. Can someone please help.
You need the wiring harness that came with the stereo in the box it was in.
Next you'll need an aftermarket radio harness which you can find here just plug in your car info.
Fit My Car aftermarket car guide
Feb 08, 2012 | Panasonic Car Audio & Video
Bought a panasonic radio model # CQ-4400U did not have a wire diagram with it
You can find a generic color code diagram for most/all aftermarket car stereos (including Panasonic) here:
http://www.siocommunications.co.uk/Wiring_files/audio_wiring.jpg
This picture should cover just about everything. If the picture has a wire that your stereo doesn't, just ignore it. Not all stereos have all color wires, and some stereos have colors or RCA jacks or plugs that aren't in the diagram. Those are usually connectors for amplifiers, CD changers, satellite radio, or something like that. The basics should all be included in this diagram though. Good luck!
Jun 16, 2009 | Panasonic Car Audio & Video
I need to install it to my camry 93
Hello capello,
Here's a link to the Camry color codes:
http://www.modifiedlife.com/1993-toyota-camry-car-radio-stereo-wiring-diagram/
If you do not want to cut or tap into the vehicle wiring, you should buy an aftermarket adapter harness and splice the wires from it and from your Panasonic CQ-C1100U together.
The Scosche part number for your Camry is TA02RB. Wiring harnesses are also made by Metra and others. Here's a link to the Scosche part:
http://www.bestbuy.com/site/olspage.jsp?skuId=9074137&type=product&id=1218016141744&ref=06&loc=01&ci_src=14110944&ci_sku=9074137
Hope this helps.
Apr 20, 2009 | Panasonic CQ-C1100U CD Player
Getting the aftermarket stereo to keep memory
The YELLOW power wire needs to connected to an always ON fused 12v source.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 13, 2009 | Panasonic CQ-DF203U CD Player
Jun 19, 2007 | Panasonic CQ-C8303U CD Player
Car Audio & Video Logo
723 people viewed this question
Top Panasonic Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Michael Thomas
Michael Thomas
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
