Question about Hitachi Televison & Video
SOURCE: no picture on my hitachi 57f500 when i connect hdmi to dvi from new dvd Player
If you have a 2006 or later model, you must set up Blue Ray DVD to Auto Mode on their output setting.
Posted on Dec 29, 2007
SOURCE: UPGRADE MY HITACHI
Go to MENU>SETUP>UPGRADES. Jot Down Your Software version. Call Customer Support at (800) 448-2244. Give them your current software version, Model number, and TV Serial Number, and they will tell you if you need upgrade. If upgrade needed, they will mail out MMC card with instructions for upgrade.
Posted on Nov 23, 2008
SOURCE: I would like to know
Yes. You need to have a DVI connector on your PC for direct DVI-DVI connection or you can buy a DVI-VGA cables for around $25 bucks. Then, after connected, go into your display properties and adjust your settings. Hope that helped.
Posted on Feb 06, 2009
SOURCE: i have a hitachi 65s700. why would i need to
software change all the time. If you want everything to work properly you need to keep it up to date. Programs may stop working or freeze up if they are not in sync. It is up to you, but it is a good Idea.
Posted on Sep 08, 2009
SOURCE: No picture (black screen) using a HDMI to DVI
MAKE SHURE cable is good and connections are good . also make shure your tv is set to dvi input. J.D.W.
Posted on Jun 25, 2010
DVI-HDTV Input (Input 1)
Use this DVI-HDTV Input for your external devices with DVI-HDTV output such as a Set-Top-Box, high-band DTV decoders, DVD
players and D-VHS with Digital Content Protection
1. Only DTV format such as 1080i, 720p, 480i and 480p are available for DVI-HDTV input.
2. The DVI-HDTV input is NOT compatible when used with a DVD player from a personal computer.
3. When connecting a Set-Top-Box with a copy-protect digital out terminal, a high definition picture can be displayed
on the screen in its digital form
OK.
