The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock.
F3 Problem:
Shorted or open oven temperature sensor (RTD):
Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
HI thanks for the question. you can by pass the clock so the oven will work without the timer. call a tech near you, and ask them to by pass the timer. if i could get the wiring diagram, i could tell you how . its a simple thing to do. thanks the appliance doc. please rate my answer.thanks
