Manual says I have a 10 year warranty on the magnetron. The microwave is only 5 years old and not heavily used.
SOURCE: Cannot heat
Sounds like it overheated, tripped the thermostat, then the thermostat reset. Chances are you have a bad magnetron. GE may have a campaign (not a "recall", mind you!) to offer free replacements if yours is a model that has a known history of problems with the magnetrons. I would call GE and ask them about that. *grin* GE Answer Center 1-800-626-2005 24 hours a day, 365 days a year
SOURCE: Re: microwave does not heat
Is very unlikely that there could be any other electrical failure since everything else seems to be working.
If you are able to fix it yourself then is way more cheaper just to buy the magnetron.
Click here to find the magnetron.
Before you do any work on this device, please click here to know how to discharge the high voltage capacitor and other safety concerns when working with devices that generate high voltages.
I would say is not worth it to spend more then $100.00 for a 5+ years old microwave.
Good Luck.
SOURCE: dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
SOURCE: GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
SOURCE: Whirlpool Microwave no longer heating
Sounds like the magnetron has failed. It is the magnetron that generates the microwaves that heat the food. If it or the circuit that powers it fails then it stops heating. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Does it heat? If so, then The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
The light failure often occurs when a bulb goes out and the filament shorts, causing a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
