Question about Polaroid Cameras
I bought a Polaroid power pack, a pink one. I have tried to charge my cell phone Without success.
I am not happy...... The light on the polaroid power pack is red when I put it on to charge, does this mean it is fully charged?I threw the box away believing the power pack would be fine. Help.
Posted by Moyra Buchanan on
Mikey
    Top Expert:
  • Polaroid Master
  • 6,489 Answers
Red means it needs charging..... the light will turn green or go off when fully charged.
Posted on Aug 22, 2017
  • 1 more comment
  • Moyra Buchanan
    Moyra Buchanan Aug 22, 2017
    Thanks
  • Moyra Buchanan
    Ok it shows red then immediately the light goes out. I've just plugged it into my phone and it's not charging. I haven't seen the power pack light go green. I think it's a dud!
  •  Mikey
    Mikey Aug 22, 2017
    Yes it sounds like you have a faulty power pack.
5 Related Answers
samkong
Samuel Konger
  • 106 Answers
SOURCE: wont turn on
Please check the charger connector for dirt, if possible take an old toothbrush and clean with alchohol, let it dry and refix everything. should work.
Posted on Jul 25, 2007
Anonymous
  • 45 Answers
SOURCE: My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
Posted on Nov 07, 2007
Anonymous
SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
Posted on Feb 21, 2008
Anonymous
  • 58 Answers
SOURCE: battery won't charge
sounds like the ac adapter isnt working.Test the adapter with a volt meter.The sticker on the adapter should tell the output voltage.
Posted on Mar 25, 2008
Anonymous
SOURCE: Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Posted on Jul 19, 2009
How can a Polaroid Pogo printer works without battery, directly connected to current?
If you a reasonably handy you could disassemble the battery pack and replace the cells with new NiCad or NiMH units. They are not complicated and you should find lots of sites on the net that will supply the cells. Alternatively if the unit has a DC socket you should find the voltage and current printed beside it. Try fitting a suitable power pack.
Sep 08, 2014 | Polaroid POGO Office Equipment & Supplies
Classic polaroid camera don't know how to tell if it works
All film pack contain a 6v battery pack. It sounds like this one had only enough power to charge the flash and turn on the green ready light. There may not be enough power left to take the picture and eject the film. You will need to try a new film pack which will have a new battery.
Mar 27, 2014 | Polaroid One600 Classic Instant Camera
I can't get my Polaroid Bluetooth wireless speaker to work!
hold the button down and it will change to blue, then you need to make sure your phone is connected to the speakers bluetooth. then when you play music off you phone it will come out the speaker. the red light is for aux mode - where you plug your phone or ipod in.
Jan 27, 2013 | Polaroid Radio Communications
Just wont polaroid film for the spirt 600cl camer near ng172fu maybe a phone number
Polaroid film has long been discontinued and as of this week every remaining unused pack has passed its expiry date. You will not find any retailers in Sutton-in-Ashfield or anywhere near which sells it any more. There is a company which has just bought the machinery and rights to re-manufacture the film, but if production goes ahead it will not recommence until 2011 at the earliest and it will be an expensive specialist product.
You can still find it on auction websites and also at camera jumbles, but be careful. Old film can have unpredictable colours and contrast, and the camera rollers often fail to squeeze the developing emulsion across the entire photo. To prevent this some retailers will claim to have kept the film refrigerated. Unfortunately Polaroid film has the camera battery built in to it and refrigeration considerably reduces the battery life. This is not a problem if you modify your camera to take an external battery but without the modification your film pack may be useless.
The last few "fresh" 600 film packs I saw were going for around £30 per pack and each pack only gives ten photos.
Oct 14, 2009 | Polaroid Photography
What powers the polaroid 600 camera????????????????????????
The battery for the Poloarid is in the film pack.
Each film pack has enough battery power to shoot the film in the pack.
The problem is that if the pack sits around for too long the battery will die making the film pack useless.
If this helps please vote for my solution.
Aug 23, 2009 | Polaroid One600 Pro Instant Camera
T831 polaroid camara
mi camara no salen las letras esta trabada
Oct 15, 2008 | Polaroid i832 Digital Camera
PINK POLAROID CAMERA
Regional Headquarters: Polaroid Corporation
Corporate Headquarters
300 Baker Avenue
Concord, MA 01742-2131
Phone: +1 781-386-2000 Digital Cameras phone: 1-877-388-3779
Polaroid Support
Hope this helps
Mar 29, 2008 | Cameras
Polaroid DVD Player won't charge.
I had the same problem, which I attributed to having the plug in a power strip. Once I plugged it directly into the wall socket, I haven't had a problem since.
Oct 18, 2007 | Polaroid PDM-1058 Portable DVD Player
Polaroid 600 instant battery change
The batteries that power the 600 format cameras are in the film pack, not in the camera. When you insert a new film pack, you're installing new batteries at the same time. hope this helped
Jul 29, 2007 | Polaroid 600 Business Edition Instant...
Cameras Logo
59 people viewed this question
Top Polaroid Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Lee Hodgson
Lee Hodgson
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
