Photos scan, slides do not - photos save to memory disc not slides.
SOURCE: 7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
SOURCE: [[ I need instructions for scanning slides on visioneer 9520 photo scanner
Go here to get the manual, software and drivers:
http://support.visioneer.com/products/home/EOL/9000/downloads.asp
SOURCE: Scanning slides into computer
From Lexmark's website:
To scan negatives, slides, and transparencies, you need to place the original between the light source and the sensor array so that the light passes through them before hitting the sensor. However, Lexmark scanners place the light source and the sensor array on the same side in order to catch the light as it reflects off the original. Accordingly, in order to scan originals of this type, you need a transparency adapter (also called a TPA or TPU), which is a back light that replaces the scanner cover.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
