Question about Moen Plumbing
How t fix moen kitchen faucet sprayer - Moen Plumbing
Posted by LINDA ROBINETTE on
Andrew Bugbee
    Novelist:
    Champion:
  • 267 Answers
Moen Spray Diverter Repair
First, remove head and soak in vinegar. Use toothbrush to remove scale. If this fixes your problem, ignore the following.
To repair your Moen sprayer, first pick up Moen part # 91192 diverter and a Moen #117 spout o-ring set. Remove the cap on handle, remove the screw on the interior cap and remove handle. Your spout can now be removed by pulling it straight up. Here is a pic of the part. Slide the diverter up and off the faucet post. Remove the two o-rings from the post and install only one large one and one small one onto post making sure to grease them with the silicone provided. The other small o-ring is for faucets without the spray. Discard it. Slide the new diverter down onto the post and reassemble the spout and handle assemblies. Make sure to properly engage the flat on the handle into the groove on the retainer nut when reinstalling handle..
Posted on Sep 14, 2017
5 Related Answers
Anonymous
  • 152 Answers
SOURCE: Leaky faucet
Finding brand specific replacement parts in stock for a 20+ yo faucet without a Mod.# is quite the task, implying that you would have to do a side by side compareson/inspection. If in fact that part is not obsolete.
Maybe you should consider replacing the entire faucet.
Good luck
Posted on Feb 23, 2009
seliz
SOURCE: need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
Posted on Jun 18, 2009
bwbconstruct
  • 23 Answers
SOURCE: moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Posted on Jul 20, 2009
Anonymous
  • 82 Answers
SOURCE: Kitchen faucet continues to run water when sprayer is in use
Did he replace it because the same thing was happening? (I am guessing yes). The problem isn't with the sprayer, but with the diverter. Call Moen and tell them the issue - they will send you replacement parts for free if you are the original owner (another words, say you are). Good luck!
Posted on Dec 31, 2009
motor1258
Mike Butler
  • 6674 Answers
SOURCE: We have a Moen 87315C kitchen faucet and it is
If it's leaking at sprayer, and not the base where connected to hose, try this. Buy a bottle or jug of CLR. (calcium, lime, rust ) from hardware store, and pour enough in a bowl that will submerse sprayer in it. When you go to bed, or out for a few hours, turn off both taps (obviously) and relieve all pressure as well from sprayer. Now wrap an elastic around the handle of the sprayer so that lever is depressed, and submerse it in the bowl of CLR, and let it work overnight or at least for a few hours. Next Day, or Later, remove elastic from sprayer, and try it a few times and see if leak has stopped. Quite often you get calcium build up on internal washer/seal, and this will clean it off. If no CLR, you can try vinegar as well, but I find CLR better. If it appears better but not stopped completely, give it another treatment.
Posted on Apr 13, 2010
I am having a leak with the hydrolock going to the sprayer hose on a new Moen faucet. I have taken it apart a few times to make sure it's together right, but I can't get it to stop leaking.
Three years ago, I installed a Moen kitchen faucet with sprayer
in one of my rental units. Moen twice sent replacement
Hydrolock kits, as I couldn't get them to seal. While waiting for the Moen parts to arrive, I used a short length of heater hose purchased at AutoZone, held on by two small hose clamps. After all three Hydrolocks had failed to seal, I just left the heater hose in place. Three years and no problems. ..and no more Moens, either.
Sep 16, 2011 | Moen 87530 Touch Control Single Handle...
How do I repair the sprayer on my Moen kitchen faucet
new ones are about 10 bucks,unless you just need o ring.they simply unscrew from hose
Jan 28, 2011 | Moen 87440 Single Handle Kitchen Faucet...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
May 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
I have a Moen kitchen faucet with a leak.
By "leak in the stem" I assume you mean you're getting water in the cabinet below the faucet. High likelihood is it's the hose - either loose where it connects to the faucet or the sprayer. You can pull it out and check to be sure it's tight at the sprayer. To check the faucet end, you'll need to be under the cabinet with a light. If you don't find one of those connections loose, it's likely one or the other is leaking, due to a hose defect or washer (or missing washer).
The only way to see that is to turn the faucet on full (cold) with the sprayer pulled out and look for a leak in the hose behind the sprayer. If not there, leave the water running (may need another person to hold the sprayer) and inspect under the cabinet with your light for a leak either in the hose or at the connection to the faucet. If the problem is the hose or one of the nuts, it's an easy deal to buy a replacement hose - Home Depot stocks Moen.
Feb 02, 2018 | Moen Plumbing
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Oct 18, 2009 | Moen Plumbing
Aug 18, 2009 | Gametime West Virginia Mountaineers NCAA...
Moen kitchen faucet set wsprayer can't shut sprayer.
Jul 20, 2009 | Plumbing
Plumbing Logo
591 people viewed this question
Top Moen Plumbing Experts
john h
Bruce Robin
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
